Resistor tolerance has 1% given in the datasheet. Does it include all (ageing, temperature co-efficient, solder joint and manufacturer tolerance.)
For my worst case can I consider 1% alone? Does it include all the error influences of the resistor?
winny
  • 14,707
  • 46
  • 66
    What does the datasheet say? Usually they are pretty specific about the test conditions for each specification (though you may not have access to the standard). – Spehro Pefhany Mar 25 '22 at 04:45
    The Photon has some comments on this. Worth a read. – jonk Mar 25 '22 at 05:49
    If you read the datahset carefully, you'll probably find it described as 'initial tolerance'. You have to add ageing and tempco on top of that. Link to the datasheet. – Neil_UK Mar 25 '22 at 06:11
  • Normally just manufacturing, temperature comes on top of that. – winny Mar 25 '22 at 09:31
  • Read the complete datasheet very carefully. Look for application notes from the manufacturer. – Uwe Mar 25 '22 at 11:05
Resistor tolerance only refers to the initial nominal value.
All other effects are either unspecified or specified separately. Typically, basic "non-precision" resistors will only specify maximum tempco, in ppm/C. Resistors targeted for precision applications will also specify the curvature of the tempco, voltage coefficient of resistance, aging, etc.
