I am trying to build a differential amplifier using the lm741 op amp, and simulate it in LTSpice. The dynamic range of the output is too small (about 20mV), I use a rectangular wave (3.3V) and 1.8V DC Input and want to amplify this input difference. Anybody knows the reason, why the output dynamic range is too small? Thanks in advance, Ahmedenter image description here
Null
  • 7,603
  • 17
  • 36
  • 48
MoMoIsBack
    What are your supplies? You are almost certainly using supply voltages that are two small -- you need a negative rail because the 741 can't drive its output all the way down to the negative rail (in this case, ground). – Null Mar 03 '22 at 15:00
  • You need split supplies of typically about +/-15V, but note that a 741 cannot get all the way there. (2) with a voltage gain of 7, and 3.3V in, you expect about 23V out - can your opamp do this with the supplies you give it? (3) note your input is DC coupled, think about the DC level on each input, and what the output is trying to do.
  • – danmcb Mar 03 '22 at 15:18
    Some relevant background reading about 741 op-amp behaviour / limitations: "Reasons not to use a 741 op-amp?" – SamGibson Mar 03 '22 at 15:37
    Bury the antique 741 opamp. – Audioguru Mar 03 '22 at 15:57
    Agree, there are hundreds of better choices. And ~dozen with superb specs, under $2 at Mouser, like OPA196, OPA207, OPA2196, OPA2990, OPA2991, OPA4990, TLV9102, TLV9104, TLV9152, TLV9302, TLV9304, TLV9352, TLV9354. – Rich S Mar 04 '22 at 21:09
    @RichS While I'm sympathetic to criticisms of the antique LM741, it has weaknesses that are reflected in more modern op-amps. OP really needs some kind of metric to zero in on the specs that matter. Suggesting a more modern op-amp that is inadequate because it has a 2.5MHz GBW (OPA196) does not really help things, IMO. It's 2.5x better, but still nowhere near good enough. And it won't give the calculated ~35V output with a 5V supply, of course. – Spehro Pefhany Mar 04 '22 at 23:04
