I am using a ACM70V-701-2PL-TL00 Datasheet to attempt to filter out A/C ripple in an in-vehicle audio device. I've run the input 12v through one channel of the choke and I attached the other channel to the same ground pour on both ends.
This is not correct, is it? I assume that I should instead split the ground into two polygons with the choke bridging them, correct?
Right now, the choke is not effective, so I am trying to run through what I've done incorrectly.
