-1
I was given a problem-based learning assignment that told me to find and explain the *circuit that consists of 2 or more LM741 op-amps. Based on my research, I only managed to find a "three op-amp instrumentation amplifier." That's a circuit structure that can amplify the differential signal while stripping off any common-mode voltage. It clashes with other team's topic, though, so I'm here to ask if there is any other circuit type that fulfills the question criteria that I mentioned above.
I just need suggestions on the circuit type's name and will do the research on my own afterward.
JRE
  • 71,321
  • 107
  • 188
brian
  • 13
  • There are basically endless possibilities. You could look into analog pulse-width modulation (pwm), just to mention one example. – Lars Hankeln Jan 15 '22 at 07:33
  • It's called an Instrumental amplifier or INA for short, that uses laser-trimmer resistors for almost ideal CMRR. 120 dB = 1e6/1 – Tony Stewart EE75 Jan 15 '22 at 07:36
    A Google image search for "dual op-amp circuits" gives plenty of results. You might also be interested in reasons-not-to-use-a-741-op-amp on this site. – Transistor Jan 15 '22 at 08:07
  • here one : https://electronics.stackexchange.com/questions/604113/output-voltage-of-instrumentation-amplifier-configuration/604350#604350 – Antonio51 Jan 15 '22 at 08:14
  • "problem-based learning assignment" = question!!! – Andy aka Jan 15 '22 at 09:57
  • @Andyaka HI there, yes indeed that's problem-based learning. But I'm here not for the answer but getting "direction/suggestion" on finding those circuit types. I am asking here as I kept getting the same and only result ( which is known as three op-amp instrumentation amplifiers) and this circuit has been taken by other groups. This is why I'm here to get some help with the "direction of googling" :D FYI, The problem-based learning assignment requires us to make a report and run a simulation to get specific data. It's not like " What's the circuit that consists of 3 amplifiers?" – brian Jan 15 '22 at 16:02
  • Site rules: This question is likely to be answered with opinions rather than facts and citations. It should be updated so it will lead to fact-based answers. – Andy aka Jan 15 '22 at 16:32
In response to the last question of your posting I can list some very versatile filter circuits.
Under B) you can find so-called "Biquadratic" or "universal filters), which - at the same time - can provide three basic filter functions: Lowpass, highpass, bandpass (bandstop).
A) Two-opamp topology:
GIC-Filters (Generalized Impedance Converter) - most versatile topologies,
B) Three-opamp topologies
  • KHN-Filter (Kerwin-Huelsman-Newcomb),
  • Tow-Thomas,
  • Fleischer-Tow,
  • Akerberg-Mossberg,
  • Berka-Herpy,
  • Parallel structures
LvW
  • 26,610
  • 23
  • 56
