I have sent out a PCB for manufacture and the manufacturer has suggested an alternative part.
The application is a mains powered (220V AC 50Hz) device. The common mode choke is being used to filter EMI on the power lines.
The original CMC is a 30mH min @1kHz with a DC resistance of 0.76ohms.
The suggested alternative is 25mH min @1kHz with a DC resistance of 3ohms.
I raised a concern that the DC resistance was larger than the original part so they suggested they change the wire from 0.25mm to 0.3mm.
My Question is - what will this do to the DC resistance of the CMC and will it bring it closer to the specification of the original part?
I am new to the use of common mode chokes and could not find resources that mention the wire thickness - happy to look over any resources you can suggest to understand this better.
what will this do to the DC resistance of the CMC and will it bring it closer to the specification of the original part?- it will lower it but only to about 2.1 ohm and nowhere near the 0.76 ohm of the original part. – Andy aka Jan 11 '22 at 11:55
