I noticed when you start running these KBP310 bridge rectifiers in parallel the Vf goes down. From 0.998 V for 1 to 0.900 V for X4 bridge rectifiers together. Why would that be? Also, I was thinking if you run 2 bridge rectifiers in parallel but reverse the A/C leads on the second one would that lower ripple and maybe Vf a little because the rectifiers would be out of phase with each other?
schematic
Null
  • 7,603
  • 17
  • 36
  • 48
allenw
  • 19
    these IC rectifiers I don't know what "IC rectifiers" are so include a datasheet. but reverse the A/C leads If it is AC then how is reversing the connections going to change anything? Include a schematic as your question is very vague. – Bimpelrekkie Jan 09 '22 at 14:29
    if you run 2 chips in parallel but reverse the A/C leads on the second one That's phyisically impossible. Given that the two diodes are in parallel, you cannot connect one diode one way, and the other diode the other way. – Davide Andrea Jan 09 '22 at 14:49
  • KBP310. I don't have a schematic. What I'm saying is having the + and - of both chips in parallel but hooking The A/C wires backwards on the second Rectifier like this =x= the = being the chips A/C legs and the x being the A/C source going from the first chip to the second. – allenw Jan 09 '22 at 14:52
  • Welcome to EE.SE. A schematic is better than words. You can add one in using the CircuitLab button on the editor toolbar. Double-click a component to edit its properties. 'R' = rotate, 'H' = horizontal flip. 'V' = vertical flip.
    Note that when you use the CircuitLab button on the editor toolbar and Save and Insert on the editor an editable schematic is saved in your post. That makes it easy for us to copy and edit in our answers. You don't need a CircuitLab account, no screengrabs, no image uploads, no background grid.
    – Transistor Jan 09 '22 at 15:03
    It sounds like you are talking about full wave bridge rectifiers. Using two with the outputs paralleled and the AC reversed on one will not make a difference in the ripple. Bridge rectifiers are symmetrical, you get the same output no matter which way you connect the AC., – GodJihyo Jan 09 '22 at 15:49
When you start running these KBP310 bridge rectifiers in parallel the Vf goes down. Anyone know why that would be?
The basic diode (or Shockley) equation explains why: -
Image from here.
So, if the current through a diode is shared between two diodes then \$I_D\$ drops to half. So then, if you re-arrange the formula to solve for \$V_D\$ you will see that \$V_D\$ drops a little bit for a halving the diode current \$I_D\$. You probably thought that all diodes drop a fixed forward voltage irrespective of forward current? Not true. Reality is more complex.
I noticed when you start running these KBP310 bridge rectifiers in parallel the Vf goes down. From .998v for 1 to .900v for \$\color{blue}{\boxed{\text{X4}}}\$ bridge rectifiers together
Image from here.
I was thinking if you run 2 chips in parallel but reverse the A/C leads on the second one would that lower ripple and maybe Vf a little because the rectifiers would be out of phase with each other?
No, it won't make the slightest difference.
Andy aka
  • 456,226
  • 28
  • 367
  • 807
Your data and a linear model of saturated diode with bulk resistance tells you why.
.998v for 1 to .900v for X4
This means 4 Rs drops 98 mV @ 1A shared by 4 equal diodes (assumption) so 4Rs=98 mV/0.25A thus Rs of each diode is 100 mohms @ 0.25A and 1 diode will drop 0.1V @ 1A
Tony Stewart EE75
  • 54
  • 185
