I knwo when you increase the area of a transistor of a circuit, the power consumption will be increased. I just want to know why is that case?
Here is my circuit in spice
Mirage
    What kind of transistor are we discussing? And are there added contexts in what you are reading that you should include here? – jonk Nov 30 '21 at 21:45
    In what contexts? Biased how? If I increase the transistor area of the input branch of a current mirror without touching the other branch, power consumption goes down, so this statement is not true in its current unqualified form. – nanofarad Nov 30 '21 at 21:51
  • You need to consider leakage current but that might not only be affected by size. Then there is gate capacitance - the higher this is the more energy required to charge/discharge it. – Kartman Nov 30 '21 at 22:40
In your circuit there are multiple aspects of power consumption.
Static power consumption from leakage in the transistors. This is dominated by FET subthreshold consumption (VGS==0). This is dependent on W/L, and also for devices that are slightly longer than minimum side, the VTH increases with channel length slightly, but makes a significant impact on the subthreshold leakage.
Crowbar current -- generally not dominant, but this does depend on the W/L of the switching devices, an the switching frequency.
Input gate capacitance -- this presents a load on the driving devices and larger devices will generate a larger (capacitive) load.
jp314
  • 18,902
  • 18
  • 46
