I got an ST LE33 and I am providing +5V between pin 2 and pin 3 as per specs. Checked with a multimeter.
I am reading +1V between pin 1 and pin 2, without any load, no capacitors. If I put a 1MOhm resistor, the voltage drops a bit.
I took a picture of the guy in case the shop sent me the wrong item, but it reads LE33.
Am I doing something wrong?
ST LE33
Paperino
  • 215
    Are you using the correct input and output capacitors? And what if you use a larger load like a 3k resistor for 1 mA draw. – Passerby Oct 21 '21 at 22:56
no capacitors
No capacitors.
Capacitors are required. See fig. 3 of the spec sheet: 100 nF across input, 2.2 uF across output.
Just to make sure it's clear: pin 1 is the left-most pin in the picture you provided.
Davide Andrea
  • 21,104
  • 34
  • 73
