I was thinking if i use dc-dc step down converter on infrared LED 5 mm, 940 nm and The supply voltage for the DC to DC step down is 5 V from a smart phone charger then I will set it on 1.4 V exactly what IR LED needed voltage. I will use five IR led in parallel. I'm thinking now about the current that the light might break or burn out because look the detail about DC to DC max current is 3 A. But the way I will use it on my mini CCTV camera.
Here the details of the item I will use :
- DC-DC LM2596 LM2596S input 4V-35V output 1.23 V - 30 V step-down power supply.
- Module property: Non-isolation buck
- Rectification mode: Non-synchronous rectifier
- Input voltage: 3.6 V - 46 V
- Output voltage: 1.25 V - 35 V
- Output current: Rated current is 3 A,
- Conversion efficiency: 92% (highest)
- Switching frequency: 65 kHz
- Output ripple: 30 mV (maximum)
- Load regulation: ±0.5%
- Voltage regulation: ±2.5%
- Work temperature: -40° - 85°
- IR Infrared LED 5mm 940 nm
Input-output voltage difference (VI-VO): 40Vdc ( max )
Adjustable output voltage range : 1.2 ~ 37V
Working temperature : -55 C to + 150 C
Current output : 1.5A
Voltage Input : 4.2 ~ 40 V
Operating temperature : 0 C ~ 125 C
Characteristic frequency : 100 (MHz)
Module size : 35.6 (mm) x16.8 (mm)
Input mode : VIN input positive level , GND input negative
Output : VOUT output positive level , GND output negative
– MARK Sep 05 '21 at 13:44
