I need to make a 1.5 V voltage source for a motor with maximum current drain 1 A.
I made this circuit:
The output voltage without load is 1.46 V, which is fine. When I connect a load resistor which is smaller than 35 ohm, then the output voltage starts to decrease:
Load resistor - output voltage
36 ohm - 1.39 V
8 ohm - 600 mV
The maximum output current is about 200 mA while output voltage is 0 V.
Could you help me find the the problem?
The datasheet says that maximum output current should be 1.5 A.
