Assume we have an LTI system with impulse response $$ \frac{1}{\pi t} $$. Is there a way to calculate its Fourier transform to get the frequency response? I know that its classical Fourier transform is not defined since this function is not absolutely integrable, but, for example, $$ \cos t $$ is also not absolutely integrable and we treat $$ \pi\left(\delta\left(\omega-1\right)+\delta\left(\omega+1\right)\right) $$ as its Fourier transform. (We treat cos as a distribution).
Thanks in advance.
FreeZe
  • 173
  • $\cos()$ is not treated as a distribution, it's used as the exponential form:$$\cos(x)=\dfrac{\mathrm{e}^{ix}+\mathrm{e}^{-ix}}{2}$$This is what gives you the $\delta(\omega\pm 1)$. Maybe math.ee, or dsp.ee are better fit for this? – a concerned citizen Aug 04 '21 at 19:51
  • @aconcernedcitizen well, this exponent treated as a distribution so its the same as treating cos as a distribution. – FreeZe Aug 04 '21 at 21:17
According to Wikipedia #309 says
This rule is useful in studying the Hilbert transform.
The transform given in the above page is \$-i\pi \operatorname {sgn}(\xi )\$. However, it is not mentioned if the trasnform is that of \$1/x\$ or \$\frac{u(x)}{x}\$. where \$u(\cdot)\$ is the unit step function.
AJN
  • 3,831
  • 20
