I can solve this circuit with nodal analysis, however, why is $$V_a=-V_b$$ in this ideal op-amp? Can I find this relationship from Kirchhoff's voltage law?
schematic
JDoeDoe
  • 191
    Notice that $V_b$ is at GND (0V) thus $V_{ba} = V_b - V_a = 0V - V_a = -V_a$ Is that clear? https://electronics.stackexchange.com/questions/441184/op-amp-virtual-ground-principle-and-other-doubts/441207#441207 – G36 Jul 05 '21 at 15:28
\$V_a = V_b\$ because the op-amp has ideally infinite open loop gain and of course, if \$V_a\$ didn't pretty much equal \$V_b\$ then the output would be slammed against the power rails. Negative feedback ensures that \$V_a\$ pretty much equals \$V_b\$.
I'm unsure why you think that \$V_a = -V_b\$ because that would be wrong. Maybe you have messed a sign up somewhere.
Andy aka
  • 456,226
  • 28
  • 367
  • 807
  • Vb is measured with inverse polarity (+ is on ground), that's where the sign gets reversed. – Ben Voigt Jul 05 '21 at 15:42
    That is, the op-amp provides that $$(V^+ - GND) = (V^- - GND)$$ but that's beside the point. The definitions $$V_a = (V^- - GND)$$ and $$V_b = (GND - V^-)$$ lead directly to $$V_a = -V_b$$ – Ben Voigt Jul 05 '21 at 15:45
  • @BenVoigt well that's open to interpretation. The + and - symbols don't particularly seem attached to Vb and I read them as random scrawls. Apart from anything else, it makes no logical or common sense to regard Vb as the inverted polarity of Va. Thanks for the downvote. – Andy aka Jul 06 '21 at 07:15
In order to compare voltages, they must share the same reference for One of the two +/- probe paths.
Yours does not. Its inverted. So Vin- = Vin+
Since ground by definition is defined by your choice of 0V, even if floating, that is the reference you should choose.
That statement Va=-Vb is just to make you think and understand this point.
But in reality, Vdiff = Vout / feedback gain (typ) 1e5 for BJT’s .
Tony Stewart EE75
  • 54
  • 185
  • What is "feedback gain"? I rather think that Vdiff=Vout/Aol with Aol=open loop gain. – LvW May 23 '22 at 09:43
-1
Why is Va=−Vb in this op-amp?
It isn't.
IF all input and output voltages are within the device's normal operating parameters AND IF there are no over-currents or current limiting AND IF the device is a theoretically perfect opamp
THEN Va = Vb, not -Vb
In a classic inverting amplifier topology, R1 and R2 form a simple voltage divider between V1 and Vo (Vin and Vout). Negative feedback drives the R1-R2 noce at the inverting input to be equal to the non-inverting input.
AnalogKid
  • 19,998
  • 13
  • 32
