I'm studying an LDO circuit consisting of a PMOS pass element.
I cannot fully understand the meaning of dropout voltage.
I thought this is the minimum V_SD to ensure that the PMOS operates in the saturation region.
I had a hand calculation, with some arbitrary reference values:
I have a situation that the target output voltage is 5V, this means current through the MOS is 1mA.
Neglecting channel length modulation, the overdrive voltage is 3.16V.
If V_in, source voltage drops below 8.16V, V_SD <3.16V. In this situation, the MOSFET operates in thetriode region.
The loop gain will become smaller, then voltage at the opamp's non-inverting pin will decrease, resulting in smaller V_out and current.
This means regulation doesn't work properly, so 3.16 V will be defined as the dropout voltage.
If I set a larger aspect ratio, the overdrive voltage is set by a smaller valuemeaning that V_SD can be smaller.
Am I right?
JRE
  • 71,321
  • 107
  • 188
남창연
  • 81
    No. Dropout voltage is the lowest difference between vin and Vout where regulation is maintained. Where minimum Vdeopout is desired it is usually a function of the output structure. If Vgs-th of the P channel output device us usefully less than Vout at target current then dropout voltage will be mainly related to Rdson with Vgs = -5V. This will be about v= Iload X Rdson. – Russell McMahon May 17 '21 at 09:56
  • @RussellMcMahon You mean, if V_IN is 10V , dropout voltage is 5V at this situation. Namely, dropout voltage is defined as voltage dfference between source and drain, not a boundary condition of saturation region, right? Then, my conclusion of boundary condition that ensuring saturation (V_IN bigger than 8.16V) is reasonable? Starting point of dropout region .. – 남창연 May 17 '21 at 12:17
    Dropout is the limiting condition where the system can JUST maintain Vout regulated. With a P Channel FET at say 100 mA dropout would typically be a few tenths of a volt. For Vout = 5V Vin is maybe 5.1 - 5.3 V. | The FET has an available Vgs of about 5V.| Eg at 100 mA and 0.3 V dropout R_effective = V/I = 0.3/0.1 = 3 OHMS. That is a very poor FET indeed. Even with some resistance that is easily achievable for an LDO regulator. – Russell McMahon May 17 '21 at 14:17
  • @RussellMcMahon Thanks for your help, teacher :) – 남창연 May 17 '21 at 15:52
  • @남창연 You have not clarified what is the amount of current you want to go into the load ("target"). If it is not that much (some mA) you could use a JFET rather than a MOS. A BJT also would be good, possibly with worse thermal coefficient. – andrea May 30 '21 at 13:54
(EDIT: After looking at your question again, I have realized that you probably know all or most of this, and that you just need to understand the circuit in question. I have addressed that towards the end of this answer (scroll down), but didn't want to remove other explanations because they might benefit others with more basic questions and because I have invested so much time and energy writing it.)
All that you have to remember about dropout voltage is that it is the voltage loss across the pass element. In a linear regulator such as LM7805 with a bipolar, NPN, pass transistor, it is about 2V. Lower voltage loss or dropout voltage is achieved using a PNP pass transistor in a positive linear voltage regulator. Almost no voltage drop is achieved with a MOSFET as a pass element at low current, because it acts like a low resistance channel.
A picture is worth a thousand words, so I will illustrate.
schematic
As you probably know, whatever the voltage you want to get at the emitter (the output of the regulator), you need to provide the voltage that is at least a Vbe drop or about 0.6-0.7V above it in order to make the transistor turn on and conduct. Add to that the voltage drop across the resistor feeding the zener diode and the transistor base, and the input needs to be that much higher than the potential at the base.
THIS is what gives us the minimum voltage drop across the collector-emitter of the output transistor, even though most transistors have a much lower Vce drop when saturated or turned on. You simply can't turn the transistor on with the voltage lower than the emitter potential PLUS the Vbe drop AND the resistor drop in this case. Lowering the input voltage any further will also lower the output voltage, meaning the regulator is not keeping the set voltage at the output or regulating anymore.
Add another transistor to the output transistor to form a Darlington pair, and you increase the minimum input voltage requirement by another Vbe drop, or 0.6-0.7V:
schematic
simulate this circuit
You also probably know this arrangement is done to reduce the "quiescent" current which goes to waste but is necessary for feeding the zener diode. The downside is that this also requires a higher minimum input voltage equal to 2 Vbe drops plus the resistor voltage drop, easily meaning at least 1.5V "dropout" voltage.
Which brings us to LDO or Low DropOut voltage regulators. Instead of using the emitter of an NPN transistor as an output in a positive voltage regulator which needs higher input voltage to overcome the Vbe drops, a PNP transistor with its collector as an output node is used to eliminate this drop on the positive rail.
schematic
I have simply placed a box because the control circuitry for this type of regulator is a little more complex and harder to understand. The main points about this type are:
  1. No need to overcome the Vbe drop on the positive side, however >
  2. this moves the Vbe drop to the negative rail; where the NPN type output can go down to zero volts, this one can't go below the Vbe of the Q1
  3. The positive rail only needs to overcome the pass transistor Vce saturation voltage which is smaller than the Vbe and can be as low as 0.1V. This is the famed LDO dropout voltage.
  4. The base current in this type of regulator is wasted, or taken away from the output current, while in the NPN type it was added to the output, so the quiescent or self-consumption current is usually higher for LDO regulators.
Finally, if a MOSFET is used as a pass transistor, the dropout voltage can be almost zero at lower currents, and usually the lowest of all, since MOSFET does not have Vds saturation voltage rating, but a RdsON rating, meaning its saturation resistance is specified instead of a voltage drop.
The problem with MOSFET is that it needs significantly higher gate-source voltage to turn or keep it on (2-5V), so your control circuitry has to account for that.
In your case:
schematic
simulate this circuit What you can see is that the VGS voltage needs to be at least at the Gate-Source threshold voltage or VGS(th) or above in order for the MOSFET to start conducting and the regulator to function as intended. The additional requirement is that the input voltage or MOSFET source leg potential needs to be above the output voltage by the amount of voltage drop across the MOSFET drain-source channel. For the transistor in my schematic, the threshold voltage is 3.32V, and the minimum channel resistance in saturation is around 0.3 ohms. This means that even if your output voltage is at 0 volts, your supply voltage needs to be at least 3.32V just to turn the MOSFET on, and 4.32V if output is 1V.
If you experiment with the supply voltage value, you will notice that it becomes unpredictable once you go below 5.001V because that is the output voltage of 5.0000V plus the voltage drop at 1mA (0.3 ohms x 1mA = 0.0003V or 0.3mV). What happens is that because the input voltage is lower than the output voltage, the op-amp raises the VGS significantly higher than the threshold voltage in order to open the MOSFET more and keep the output at the required level, which eventually leads to the supply and VGS (and almost the output as well) voltages being equal and bringing the output voltage out of the regulation.
Now, in your case, if we add a 1A load at the output, the voltage drop across the drain-source channel will be about 0.3V, which means you need at least 5.3V input power supply. Also, at increased load currents, the needed VGS(th) increases to open the drain-source channel more. Below is the same circuit with an added load resistor. As you're editing its value, the voltmeters in the circuit instantly reflect the change even while the resistor value editing window is open and you have not saved it.
schematic
P.S.: Your formulas and symbols are a little unclear to me. I admit I'm not that good with math, but I think that you're not that good with it either, and that you're trying to comprehend a concept through mathematical formulas before comprehending it visually and experimentally, which is the opposite of how people learn and understand in general. Always try to visualize before going into mathematical formulas and equations because they only get you even more confused before you get to understand a concept.
Edin Fifić
  • 5,451
  • 24
  • nice explanation of the minimum output voltage. it also implies a substantial disadvantage of PMOS LDOs: its difficult to obtain high current with very low output voltage because you can't pull the gate down very far. – tobalt Jul 06 '21 at 20:07
  • I have added more to my answer to include the questioner's circuit and situation, as well as more about MOSFET regulators in general. Let me know what you think of it. Thank you. – Edin Fifić Jul 07 '21 at 11:17
