17
I have several lines and arcs in an EAGLE footprint library I need to modify to make thicker. In Altium it's straightforward to hold Ctrl, click on a bunch of objects, open up their properties and change them all at once. In EAGLE I have no idea.
EAGLE's "group" paradigm seems a little far-flung from the standard, so my attempts to use that may be a dead end, but is there some better way? Is there some magic command I could run to give every single line and arc in a library part on layer X a thickness of Y? How about in a PCB, smashing all the parts and changing all their labels to font Z with size W?
W5VO
  • 18,738
  • 64
  • 96
Nick T
  • 12,480
  • 45
  • 72
You probably need the change ("wrench") tool available from the GUI. But it might also worth considering using some Eagle commands for that purpose.
Assuming for example you want to change the thickness of your wires to 30 mil, first you have to select those tracks as usual, then you might issue the following commands:
change width 30 mil
(> 0 0)
The (> 0 0) part simulate the right-click required to apply changes.
If you need to change the thickness of all the wires, this might be scripted even further:
display none top
group all
change width 30 mil
(> 0 0)
display last
Sylvain Leroux
  • 284
Yes, the "group" paradigm is what you're looking for most of the time. Yes, it is as clunky as you think it is. There's no premade magic command. You can shift+drag (pretty sure it's shift, maybe control, been a while) selection boxes to add more objects to an existing group selection.
One thing you can try is to turn off all layers except the one you want to modify and then box select everything and use the group tool that way. Other than that, you may want to look into Eagle's ULP/scripting functionality to make yourself a command.
Joe Baker
  • 1,723
  • 16
  • 30
  • I've selected multiple lines, but how do I modify them all at once? If I right click, or Ctrl+right click with the info tool and edit, it just changes the line I clicked on. – Nick T Jan 22 '13 at 03:47
    Select the lines and then select the tool you want. It will appear to deselect the lines, but the group is saved. Right click anywhere, there will be a ": Group" option. You can also choose the tool before selecting the group. – Joe Baker Jan 22 '13 at 03:54
  • I'm picking group, boxing some lines, selecting the info tool, but I can't right click off away from the part (makes an error noise), and if I rt-click near a line it doesn't show an Info:Group option, just the regular tools which only seem to effect the nearby line. I have 6.2.0; do you have a newer version? – Nick T Jan 22 '13 at 05:41
    Ah, I need to use the Change (wrench) tool. – Nick T Jan 22 '13 at 06:01
  • As Joe points out you can use display to help with this. Example: "display none via;", "group" (or "group all") then select the vias, "change..." and ctrl-right click. You can use shift+click when defining a group to add it to an existing group. It's a little messy sometimes but at least you can continue to apply any change by consecutively clicking on the next item to change. (Unless you change 100 items that way and your coworker beats you with the infernal mouse). – carveone Jan 22 '13 at 11:22
Enter the command:
cha wid 0.234
Where you replace "0.234" with the width you want in whatever your current units are. This is a short way to enter the "change width" command. Most Eagle command names and other keywords can be abbreviated to three letters. For more details on the "change" command, enter HELP CHANGE.
Then just click on any wires you want changed. Yes, it really is that easy.
Olin Lathrop
  • 313,258
  • 36
  • 434
  • 925
Don't know if it is too late for this, but you could use a ULP(User Language Program) to change the width of all the traces on the board.
Go to File -> Run ULP.. -> Type "cmd-change-brd-width.ulp" -> Open
It will open up a dialog box and you can use that to change the width of multiple wires at the same time.
Chandough
  • 113
