mcp23s17
bi-directional level shifter
I have the above circuit which is able to convert Vin to 3V3. Any IO pin of the MCP23S17 can be connected to D_OUT on the level shifter. D_IN can be used for either input or output signals. The MCP23S17 is able to detect inputs and outputs logic levels correctly when used with a power supply. However, when I connect the pins to a device that has some proprietary circuit at its input pin the voltage on the level shifter output drops to 3V3. What would be the best way to implement isolation at the output of D_IN so that it can still be bidirectional. I have looked at CD4050BNSR but am unsure if it will be bi-directional. I will be very thankful for any recommendations.
Ali
