I am using the below AC electromagnet to switch on/off a pneumatic system. (It is a pneumatic actuator. I think that is what it is called.)
The issue is, when I turn off (disconnect the switch) the coil generates a big negative voltage spike in my nearby PCB electronics and cables and messes up with my LCD screen and buttons (they get randomly pushed.)
Except for having to remake my PCB to be EMI-proofed, which is costly, can I use two Zener diodes back to back to create a 'fly-back diode' for the AC current? What other techniques there are?
Pneumatic actuator: The pneumatic actuator
The initial schematic:
schematic
The one I am thinking of implementing:
schematic
simulate this circuit
JRE
  • 71,321
  • 107
  • 188
Christianidis Vasilis
  • 3,270
  • 39
The flyback diodes were too expensive to buy, and we had no other varistors here for these voltages required. So we ended up changing the AC valve with a DC one of 24V.
But the alternatives of using a higher value varistor or back to back zener diodes, would also work.
  • 3,270
  • 39
