I'm performing an experiment in which I send a sine wave into a test device and try to measure its response which will be in the order of a few \$\mu\$V. This response is obtained from the buffered output of a controller box (commercial device belonging to the setup). Because of the available equipment I would like to measure this signal with a lock-in amplifier.
The problem is that due to the nature of the test device's feedback loop, the signal may get a DC offset of +/- 10 V at random moments. While there is a TTL reset available to remove this offset as quickly as possible, I fear that the 10 V will damage the input of my lock-in amplifier (sr830).
Is there an over-voltage protection circuit that I can build in between my device's output and my lock-in's input to protect the lock-in from these occasional high voltages?
