Never thought about it until previous part I used, 3.5 mm stereo jack, gold plated, has depleted in the place I was buying it from.
Research for replacement shows that such connectors may have gold or silver plating.
(gold) or
(silver)
Ok for gold - it does not oxidize under normal circumstances, and expected to last long.
But why silver? Here's a past question on the subject; however audio does not have high currents, and several milliohms of added resistance would not make much difference for non-Hi-Fi parts. The jack is not expected to carry RF signal.
Datasheets for gold and silver plated parts state same life cycle - 5000 insertions. Prices of the parts are comparable, I would expect parts with gold plated contacts to have higher price.
So what is the difference between gold (example) and silver (example) plating in this implementation - for 3.5 mm phone jack?
I read the dozen articles on the applied differences, and can not figure out a reason why silver plating exists for this application. Moreover, the plug can be dirty or wet, and it will even more deteriorate silver plating. Then, oxidized silver is hard to solder.
@BrianDrummond if actual plating is nickel, then the only explanation is that by writing "silver" in datasheet manufacturer means color. Well, then where is guarantee that gold plating would be a gold, and not "flavor or gold"?
@SpehroPefhany: audio application has nothing to do with high power. Special medical application sounds strange. Maybe the air nearby the connector becomes saint, or vampires will be afraid coming to the room?
@MarkoBuršič: I have seen this article, it is enough to look at the conclusion:
Conclusions: Having outlined the qualities and implications of using silver as a contact finish, there are many signal connector applications where it may be a very good finish choice alternative – but only if the design characteristics and application requirements are appropriate. Appropriateness should be determined by design and application analysis as well as product testing and by addressing customer needs and perceptions where needed.
to understand that it is about nothing and does not contain answer to audio connector question.
Edit: I am wrong about this article. We can make several conclusions out of it:
  1. Do NOT use silver - article is full of reasons why not to use silver plating;
  2. Units with datasheets stating that they have silver plating over copper alloy must not be used, per article: "At higher temperatures, oxygen will diffuse through silver to the copper alloy interface at a relatively fast rate and could lead to blistering if no nickel underplate is used" -> means that proper way is to coat copper with nickel, and then with silver. If done without nickel, then manufacturer does not know what it is doing.
@evildemonic did you see chips with silver plated pins? That would be very handy is chips terminals be soldered better if coated with silver plating. Re: RF - audio has nothing to do with RF; the only application I may think of is when headphones' cable serves as antenna for mobile.
@dandavis better conductivity does not convince me that silver is better for 3.5 mm audio jack. Gold still rules?
Update: after some more research I tend to believe that contacts themselves, the pieces of metal touching the plug, may not be coated with anything at all. These contacts may be bare nickel (as declared in datasheet), or "copper alloy" (which one?) or phosphor bronze, which all are seem resistive to corrosion and provide good contact. And all this gold and silver stuff is about "solderability" and units looking deluxe gems.
I am waiting for feedback from CUI devices and Tensility.
In addition to the research on the plating, I found out that connectors with the same part number, even made by same manufacturer, may have different datasheets, with differing dimensions, differing material of contacts, differing plating... wtf... see below - the connector I used before. No dates on the sheets to identify which one is latest.
Good news from Tensility: the connector I have chosen, 54-00177, has its metallic parts - inner and outer contacts - fully gold plated.
Anonymous
  • 7,052
  • 14
  • 45
    That won't be silver; maybe nickel. Silver oxidises (used to be the basis of the entire photographic industry!) and needs periodic cleaning to make reliable contact. –  Jan 11 '21 at 22:23
  • But datasheet(s) clearly state: plating - silver (over e.g. copper alloy)! – Anonymous Jan 11 '21 at 22:36
  • Silver might be good for a power application. They mention "medical" applications. Tens, perhaps? – Spehro Pefhany Jan 11 '21 at 22:51
  • Found some article, maybe you will find something useful: https://advancedplatingtech.com/wp-content/uploads/2013/10/Use-of-Silver-in-Connector-Applications-M-Myers.pdf – Marko Buršič Jan 11 '21 at 22:57
    This is sometimes done to make reflow soldering work better. I think the main use of the silver is on the external terminals that get soldered to the PCB. – evildemonic Jan 11 '21 at 22:59
  • Also, tarnished silver is actually a pretty good conductor. You see silver in RF contacts that need to be low impedance. – evildemonic Jan 11 '21 at 23:00
  • silver conducts well, much closer to gold than copper or steel. The tiny mating surface area of the contacts will get scraped free of oxidation upon inserting a tip. – dandavis Jan 12 '21 at 04:41
  • thanks for replies to far, updated the question. Unfortunately none of these contain material reason to use silver for audio application. – Anonymous Jan 12 '21 at 06:55
    In audio oxidisation is a major issue. It causes audible distortion on very low level signals. As others have said the silver in this case refers to the PCB pins not the contacts, which are likely chrome or nickel. They will probably need to be cleaned periodically. See this : https://electronics.stackexchange.com/questions/69661/why-are-high-end-audio-connections-gold – danmcb Jan 12 '21 at 08:48
  • @Anonymous: The "recommendation" for "use in medical equipment" doesn't mean much. I've seen similar notices in datasheets for standard ICs (op-amps and voltage regulators.) Most of the time all it means is that some marketroid knows that some company somewhere used it for something medical related. If it's really meant for medical use, it'll tell you what standards it meets for its medical purpose. – JRE Jan 12 '21 at 11:07
If you look closely at the datasheets, you'll find that the silver or gold plating applies to the pins, not the internal contacts.
From your silver plated jack:
The table in the upper right corner has pin numbers.
The low left drawing shows the pin locations.
The gold plated jack has a similar table and drawing.
It's not the contacts that are plated, just the pins you solder to.
Some of the pins are copper, others are brass. From what I've read, soldering directly to brass causes problems - the zinc in the brass dissolves during soldering, gets in the joint, and causes bad joints.
The brass pins must be plated to prevent the zinc from getting into the joint.
Silver apparently works fine by itself - plate a layer of silver and you are done.
Gold requires an "undercoat" of nickel - you have to do two plating steps with gold.
Silver is easier to manufacture, gold is better if your parts will be laying around unpackaged for a while - silver tarnishes, gold doesn't.
The silver parts even specify how long you are allowed to leave them unpackaged before reflow soldering. I expect part of the reason for that is the tarnishing.
The information above comes from this paper on diffusion barriers.
It appears that silver rapidly dissolves in solder with lead rather rapidly at normal soldering temperatures - to the point that SMD capacitors made with silver end caps are plated with nickel to keep the end caps from dissolving away entirely while soldering.
That implies that silver doesn't matter much to the conductivity in the final joint. You don't have a layer of silver between the copper pad and the copper alloy pin. There's pretty much just copper, lead solder, and copper alloy together and the silver is distributed through the solder.
The paper also describes the use of gold plating over brass. Both of the connectors have at least one brass pin.
The zinc in brass can apparently diffuse through the gold plating, and some of the copper follows. The oxidized zinc and copper don't solder well.
A layer of nickel under the gold keeps the zinc from diffusing. Zinc and copper stay where they belong. The solder joint is then between the copper pads on the board and the nickel layer - gold dissolves in solder like silver does, though not as fast.
Gold doesn't tarnish, so you don't have to worry about solderability as much.
Silver tarnishes, so you (in a factory setting) would have to pay more attention to storage than with gold.
In actual use, the silver goes away and you have a joint between copper and copper with solder in the joint. Gold goes away, but leaves a layer of nickel between the copper surfaces.
I don't think any of that matters if you are hand soldering small numbers.
The choice between silver or gold might matter if you are making boards by the thousands.
Why one manufacturer uses gold and the other silver may come down to having the facilities - or maybe those companies make products with both options.
In any case, it isn't about the conductivity if gold or silver or about tarnish that occurs after manufacturing.
It's all about chemical reactions before and during soldering.
JRE
  • 71,321
  • 107
  • 188
  • Thank you for the info. From this I do the following conclusions and further questions: (1) contacts are made of "copper alloy" declared in the "material" column, and copper also tarnishes and subject to rust; (2) why silver-plated connectors cost comparable if gold require two platings, gold is more expensive and there's more space gold is applied to the gold-plated connectors than to silver-plated? – Anonymous Jan 12 '21 at 07:41
  • (3) copper alloy is expected to be reddish; why then picture of the connector has metallic parts white/grey? Nickel plating? According to the article @MarkoBuršič referred to Nickel is having enormous resistance, even tin plating is better, not mentioning gold. – Anonymous Jan 12 '21 at 07:46
    I've got to go to work. I'll quote some references for you when I get time later. Just this: It isn't about the electrical properties. It's about chemical reactions in hot lead. – JRE Jan 12 '21 at 07:56
I suspect the answer has to do with the 5,000 cycle rating typical on those parts. Gold is soft and there is a lot of wiping action in the 3.5mm connector design.
So you might find (too thin) gold flash in cheap jacks that will not retain the gold plating for many operations or thicker silver. Or thick and/or selective gold or gold alloy on better connectors.
Pro-audio connectors such as XLR are offered in both silver and gold versions, with a typical part such as the AAA3FBAUZ from Switchcraft coming in at about 50% more expensive in a gold version with the same rating.
There seems to be a plethora of bovine excrement in "audiophile" forums. I suggest going to a manufacturer who offers both and actually does engineering (not just sticking their name on imported products) to get technical recommendations.
Spehro Pefhany
  • 397,265
  • 22
  • 337
  • 893
I do believe the ansewr is non-technical. Gold is in fact more expensive. Let me explain.
As per advancedplatingtech.com the minimum thickness of a gold plate would be 0.1µm. Let us assume 50mm² of metal to be plated that gives us the amount of gold needed for one audio jack: 5e-12m³ = 5e-6cm³. 1kg of gold is 67cm² and cost 60e3US$. That means the gold on the jack is nearly 0.5 cent (somebody check this please)! And if you use a more propper thickness the cost might even go up to 1 cent and more.
In mass produced ultra-cheap electronics this is a lot of money.
For us buying single parts that does not make a difference.
Tim
  • There's a strong sense in your reasoning; and the problem is exaggerated by the datasheets missing the information. For example, none of them state what is the plating on the contacts touching the plug. But the conslusion basing on your answer is that non-gold connectors are either for low-end market, or for special purposes (e.g. coating with special metals to withstand within military or space applications). – Anonymous Jan 12 '21 at 09:54
