I would like to measure the power of a very unusual ac waveform. Please say if this could work...
Construct a black pvc tube with a very sensitive light to voltage converter TSL257 in one end, and a tiny lamp in the other end, seal both ends.
Drive the lamp with the waveform to be measured and record the lamp intensity voltage from the TSL257.
Drive the lamp again with a battery to the same intensity and calculate the power ( Volts @ Load x Amps )
Would this method be similar to the old "Hotwire" ammeters?
Thanks.
