Lets say I have a 1km long transmission line with a characteristic impedance of 50ohm. With a pulse generator I inject a really long pulse (30µs) the pulse generators termination is also 50 ohm. The response will look like the image below
Tenter image description here
So the amplitude U/2 of the reflections is because of the voltage divider formed by the two 50 ohm impedances. When using a signal generator with a known resistance (impedance) we should be able to calculate the impedance of any cable by the amplitudes of the reflections. Is my assumption correct?
Yoomo
  • 363
It's a little bit easier than that - you don't need to wait for the reflection; at the point you apply the signal (50 Ω source), it is the voltage instantly developed at the cable that determines the impedance. For instance, if your pulse is 1 volt and has a source impedance of 50 Ω and, it connects to a 100 Ω cable, the voltage seen at the cable is: -
$$V_{CABLE} = 1\text{ volt}\cdot \dfrac{100}{100 + 50} = 0.6667\text{ volts}$$
If the cable were 50 Ω impedance then the peak voltage is 0.5 volts.
Andy aka
  • 456,226
  • 28
  • 367
  • 807
  • But this assumes that the impedance of the cable is a real value? – Yoomo Dec 20 '20 at 12:22
  • @Yoomo If you are using pulses then this is going to be the case. The characteristic impedance will be $\sqrt{L/C}$ and that will be resistive above 1 Mohm. – Andy aka Dec 20 '20 at 12:24
  • So with your formula I can calculate the impedance of the cable, when I am using either a pulse or a DC voltage? – Yoomo Dec 20 '20 at 12:26
  • @Yoomo use a pulse and pretty much after applying that pulse (via a resistor) look at the magnitude at the cable end where you apply the pulse. If the cable is short then you might get a reflection coming back too quickly and it screws up the measurement of course. – Andy aka Dec 20 '20 at 12:29
  • I am a bit confused. When I use a long square wave pulse like above the impedance will be a real value and can be calculated like this Vcable=1 volt⋅(100/150)? – Yoomo Dec 20 '20 at 12:40
  • At the instant the pulse is applied, the potential divider formed by the source impedance and the cable's characteristic impedance is created. It's instant so, if you measure after 1 ns or 10 ns or 100 ns or 1 us, you will get the same result (providing the cable is long enough so that far end reflections are avoided during the measurement period). – Andy aka Dec 20 '20 at 12:55
