I got this IC in my circuit and I'm wondering if I could hook up a pull-up network to it, in the following way:
Since it's an RS485 transceiver, the input to it is differential. I need to know if I can input a non-differential voltage as an input to it.
My intention is to eventually determine the voltage that comes into the IC, if it's high then the cable is not connected and when it's low the cable is connected. (for clearance - the voltage will be determined my an MCU input reading the high/low states).
