The characteristic impedance of any transmission line is derived as
$$ Z_0= \sqrt{\frac{R+j \omega L}{G+j \omega C}} $$
where R is series resistance per unit length, L is series inductance per unit length, C is shunt capacitance per unit length, and G is shunt conductance per unit length. The real and imaginary part of the above equation can be derived assuming that \$ \omega L >> R\$ and \$ \omega C >>G\$
$$ Z_0\approx \sqrt{\frac{L}{C}}+\sqrt{\frac{L}{C}} [\frac{R}{2j\omega L}-\frac{G}{2j\omega C}] $$
According to the assumption made above the imaginary part should be very small and thus can be neglected. Therefore the characteristic impedance is almost purely real and is given by \$\sqrt{\frac{L}{C}}\$. (I know that the imaginary part appears because of non-zero value of series resistance R and shunt conductance G, which accounts for the transmission loss.)
Theoretically for infinite frequency \$\omega\$ the value of \$Z_0\$ approaches \$\sqrt{\frac{L}{C}}\$, which is a real number. But I have seen in some cases where \$Z_0\$ is reported to have both real and imaginary part at some frequency. For example, some authors reported \$Z_0=4.95+j7.6\$ ohm/m for a coaxial cable operating at 1GHz. As you see the imaginary part is even larger than the real part. For small, and constant(?) values for R, G, C, and L I expect the imaginary part to be almost zero at 1GHz. So what happened here? What could make the above assumptions fail? Does R change a lot with frequency?
