I'm designing a board for a school project using eagle. I thought I could get away with using the onboard clock of the PIC18 since it's not doing a whole lot (mostly just LEDs), but one of its tasks is RS232 communication, and I (just) learned that the onboard is nowhere near accurate enough for any sort of comms. Since the RS232 link is crucial, I need it to work. So I've had the task of cramming an xtal and two caps on my already crowded PCB. Here's my result at 3am this morning:
I'm sure I've made some experienced board designer sweat a bit. The big glowing trace is ground. I think it's the best I could do considering there was absolutely no room to move the PIC or the two top chips, and very little room to move the bottom one. The board is going to be CNC milled so I can't go less than 16mil trace width/16 mil spacing. I rearranged what I could to make sure OSC1 and OSC2 had no vias. The caps are small little ~20pf ceramics, I just used the cylindrical parts for the pad spacing.
(Also, blue is the bottom layer, red is the top; everything has to be through-hole and connect on the bottom)
I plan on running the chip at 4.9152MHz. If for whatever unfathomable reason it's not enough speed, I'd like the option of 7.2MHz. I know speed affects design.
Any advice would be appreciated. I'm probably going to spin the caps so the trace to the xtal is shorter. I don't see any possible way to have a 'ground ring' which is suggested as there's no room.
EDIT: Here's an updated design. I switched out the caps with a better footprint (still ceramic), and the microcontroller connects to the ground plane at only one point. The dashed lines show where I'm going to put my guard ring (pins 1 and 20 of the TPIC are N/C):
Edit 3: Fatter traces, better shielding, I think this is as good as it can get:
Even though the earlier question is about an SMT layout, the same basic principles apply.
– The Photon Jan 06 '13 at 18:08delay_ms(x)or some sort of, and you are using bit-banged RS232, internal 8 MHz oscillator is fine, and I have tested it. However, I don't know how its performance will vary over the temperature span of your design. Just saying.. It is good that you learn proper layout , and I hope you will learn it good. – abdullah kahraman Jan 06 '13 at 20:56
