I want to graph \$h[n] = \frac{1}{n+1} \ n\in [0,29] \$
I tried the next code, but won't compile:
n=linspace(0,29,30);
h =1/(1+n);
figure
stem (n,h);
Trygve Laugstøl
  • 1,410
  • 19
  • 28
You need to add a dot in front of the divide symbol (this means array divide as opposed to matrix divide):
h =1./(1+n);
figure
stem (n,h);
Resulting Graph:
Matlab Example
To find out more, type help . - you will get something like this (this is only part of the result, as it's rather long...):
>> help .
  Operators and special characters.
  Arithmetic operators.
    plus       - Plus                               +
    uplus      - Unary plus                         +
    minus      - Minus                              -
    uminus     - Unary minus                        -
    mtimes     - Matrix multiply                    *
    times      - Array multiply                    .*
    mpower     - Matrix power                       ^
    power      - Array power                       .^
    mldivide   - Backslash or left matrix divide    \
    mrdivide   - Slash or right matrix divide       /
    ldivide    - Left array divide                 .\
    rdivide    - Right array divide                ./
Oli Glaser
  • 55,140
  • 76
  • 148
    I would like to add that n=0:30; is cleaner and easier. In practice, this error is solved by adding dots util it works. Eventually, you will know the cases in which it is needed. – Serge Jan 05 '13 at 16:36
    @Serge - agreed, a simple integer array might be better. Matlab gives you plenty of hints on the errors too. – Oli Glaser Jan 05 '13 at 17:48
