29
From what I understand, USB has 4 lines just like an audio port. So why can't we have a USB port which is circular? I feel it can be more convenient to plug in and also would have a smaller form factor. May be, we can have the same 3.5 mm jack port switch between analog audio output and a digital USB function. What am I missing?
chicks
  • 187
samwise_the_wise
  • 469
    The problem of shorting things while plugging in and out and not plugging in all the way and contact problems you encounter after using it for a few years? USB-C is almost round, so all problems solved. – Arsenal Oct 23 '20 at 11:30
  • 32
    consider a USB type C plug, as a round connector which has been hammered to get a lower height – Tirdad Sadri Nejad Oct 23 '20 at 11:47
    Shorting things in and out, needing a deep connector, the list goes on... (already covered in the good Answers you've received). Have you noticed connectors have long since evolved away from 1/4" and 3.5 mm 'stacked contact' style and into side-by-side contacts. No-one's trying to go in the opposite direction, which you're proposing. – TonyM Oct 23 '20 at 12:20
  • 16
    USB-3 has way more than 4 lines. – brhans Oct 23 '20 at 14:13
    The iPod Shuffle 2G used a TRRS jack for both headphone out and USB docking. https://en.wikipedia.org/wiki/IPod_Shuffle#2nd_generation – endolith Oct 23 '20 at 17:21
    It's kind of a shame, a lost fantasy. I think all connectors in sci-fi I saw like GitS were round. The main benefit of round connectors being, I imagine, that it's way easier to connect quickly without looking, like when the socket is at the back of your neck. You never need to think about orientation of a socket, so it's simply more ergonomic. – JoL Oct 23 '20 at 20:02
    There is nothing new about Apple inventing pointless, non-standard hardware interfaces simply because (1) it can and (2) it means that Apple aficionados have to to buy more merch. – alephzero Oct 23 '20 at 20:39
  • Also it's a form factor which can be terminated by machine. Most round connectors rely on the conductors being terminated by machine and then inserted into the housing manually, while Ethernet is spectacularly labour-intensive. – Mark Morgan Lloyd Oct 24 '20 at 12:02
  • 14
    That would never work. With a round connector it could be inserted in any orientation, and part of the USB spec is the first 2 attempts to insert the connector must have a chance of failing... – Harper - Reinstate Monica Oct 25 '20 at 02:41
  • You are missing the performance impact. – copper.hat Oct 26 '20 at 02:56
  • There are circular USB connectors (google M12 USB, e.g. https://www.automation24.de/m12-usb-verbindungsleitung-murrelektronik-334003 ) – Haukinger Oct 26 '20 at 09:59
  • @alephzero Please give us some examples of pointless and non-standard hardware interfaces. – gnasher729 Oct 26 '20 at 11:06
    @gnasher729 Lightning cables are proprietary, ergo non-standard. And while it may be better than some USB technologies, USB-C has long since surpassed it. Yet Apple insists on continuing to use lightning -> pointless. – JLRishe Oct 26 '20 at 14:15
  • Audio jack is well-known for killing electronics which try to use it with digital signals and don't tolerate shorts. – Dmitry Grigoryev Oct 26 '20 at 15:21
    @alephzero there's nothing new about haters bitching at Apple for everything they do, whether it is in fact good or bad. – Almo Oct 26 '20 at 19:33
  • With USB as is, there are two ways to connect it, and one of them is wrong. With USB-C, there are two ways to connect and both work. Which is nice! With a round connector, there are an infinite number of ways to connect it and only one works. That would suck. Round connectors actually suck because they are difficult to align. – user57037 Oct 29 '20 at 23:17
6 Answers6
48
Rotatability while the USB connection is already established is a feature you don't want:
While for audio frequencies, the electric ringing caused by imperfect contact are benign enough to not matter, I wouldn't trust that to be true for 1 Mbd (low-speed USB1), and certainly not at 12 Mbd (Full-Speed USB1.1), 480 Mb (High Speed USB2), or the gigahertzes of bandwidth that USB3.0 and later generations use.
In fact, for the latter, you need pretty well-matched connectors that are designed to conduct an RF signal instead of a current. Building such connectors even in rotatable form is, if at all possible (never saw a rotatable connector that has more than one waveguide, e.g. coax connection), extremely expensive. Think of > 20€ per connector, even in larger quantities, and, due to physics, probably not very compact.
I was surprised to find out there's actually USB3 slip rings! They look like this:
UM0155
Marcus Müller
  • 94,373
  • 139
  • 252
    They do make twinax cable, connector, etc. They are a bit on the expensive side though. For one (admittedly somewhat extreme) example: https://www.milestek.com/p-13458-plr75c-201-trompeter-twinaxial-cable-plug-trb-3-slot-male-right-angle-full-crimp-m17176-00002.aspx – Jerry Coffin Oct 24 '20 at 20:54
    nice! That'd be at least one of two differential superspeed pairs for USB3 :) I love how literally every part of this connector (see the drawing PDF) screams "defense/aerospace" – Marcus Müller Oct 24 '20 at 20:58
    Yes--my experience with them is with MIL-STD-1553 and NATO STANAG 7221 communication (where 7221 is defined specifically to run over existing 1553 wiring). The price tag alone seems like a pretty solid military/aerospace-only indication, at least to me. – Jerry Coffin Oct 24 '20 at 21:09
  • I wasn't even aware of STANAG 7221; pretty new (read: twice as expensive) stuff indeed. (pretty low specs in terms of data rate by modern communication standards, though) – Marcus Müller Oct 24 '20 at 21:17
  • Well then the answer seems pretty simple: a USB port should consist of a rotatable audio connector for basic signaling, and 5 interchangeable coax connectors which have to be screwed in individually... – user253751 Oct 26 '20 at 09:59
  • @user253751 that would be crazily useful! – Marcus Müller Oct 26 '20 at 10:31
    @MarcusMüller no it wouldn't – user253751 Oct 26 '20 at 10:32
    @user253751 :) "a sarcasm detector? Woah, that's a really useful invention!" (device goes up in smoke) – Marcus Müller Oct 26 '20 at 10:35
  • @JerryCoffin What you've linked is a triaxial BNC connector for adapting twinax cable to triax - those do not rotate. They are locking connectors, like standard coaxial BNCs, and once they're connected they cannot spin. That would be disastrous for the signal. – J... Oct 26 '20 at 13:20
31
USB connector is specifically designed to allow for safe sequence of pins contacting firmly for hot plugging and disconnecting, passing the rated amount of current, and not being able to connect incorrect cables or devices.
None of this applies to TRRS connectors. It will short out various pins during insertion and removal. It will rattle and crackle after some amount of mating cycles. And since 3.5mm connectors have been used for headphones, mics, line level audio, IR transmitters, IR receivers, and even for power supplies, there is a good chance two incompatible devices are plugged together and it does not work or causes damage.
Justme
  • 147,557
  • 113
  • 291
    iPod Shuffle 2G did it – endolith Oct 23 '20 at 17:21
    @endolith that one used a docking station though, that connected via USB and (presumably) made solid contact with the pod before attempting to shove data through a 3.5, then performed a complex mating ritual to identify itself as an Apple USB docking port and then used now affixed 3.5 wire pair as a PHY for data transfer. If it was a dongle form, I presume the data rates would be abysmal to non-existent during times the device was moving. – John Dvorak Oct 24 '20 at 07:13
  • @JohnDvorak all true – endolith Oct 24 '20 at 10:13
  • Round doesn’t necessarily mean T(RR)S. Power supplies often use coaxial connectors to prevent shorting. A variation often found on laptop power supplies has a pin in the center of the power plug. One could build on that, giving that pin a tip and sleeve, with a wide-enough insulating ring in between to prevent shorts during insertion. Or one could put separate contacts on the inside and outside of the barrel in addition, or even have multiple concentric barrels. OK, this does not scale well above 4+ contacts, and there may still be signal quality issues if the plug is rotated while inserted. – user149408 Oct 25 '20 at 15:59
21
There isn't really any reason we couldn't have a round connector. But there are reasons why the existing connector designs are better:
  1. It's hard to have a round connector with shrouded contacts. On all USB connectors it is physically very difficult to touch or short out the actual electrical pins. Even if the cable brushes against metal surfaces it is unlikely to happen. You would need to intentionally jam something metallic into the connector to achieve this. This was of particular importance when USB was first designed as ESD protection wasn't very good, and the power supply for the port was not switched (as it is now for USB-C). Having an unshrouded connector like the 3.5mm jack would have required extra protection for the pins and this would have added cost. There can also be more corrosion problems when contamination can be more easily transferred to the pins (e.g. Ligthning connector) and the pins are more susceptible to mechanical damage.
  2. Hot-plugging is harder. This is not dissimilar to the first point, but in USB connectors the ground pins (and shield) are designed to connect before signal pins. If you have a 3.5mm type plug then the tip contact will run through the other contacts before it reaches the correct one. This can be dealt with, but it would require more protection circuitry and hence more cost.
  3. The width of the connector isn't that important. Most devices you'd connect to are not round. They are normally rectangular and in most cases the critical dimension is thickness (e.g. phone, flash drive). If you had a round connector you'd have to make it longer to hold all the contacts at the expense of the width. For most types of products this is not a desirable tradeoff.
Jon
  • 5,057
  • 14
  • 20
11
I have actually seen USB carried through a 3.5mm TRRS connector, which is also used for headphones, so it's possible. This is on a waterproof MP3 player, where adding another sealed socket would add cost and bulk. The other end of the cable is a standard USB-A, so both the device and the host computer must be able to handle hot-plugging. I have no idea of the data rate this device tries to obtain.
In general, running power over male T(R)(R)S connectors is a bad idea. I've got hardware in work that does, and is also designed to be used on metal tables (photodiode modules and optic tables). Geometry means shorts are rare, but they do happen, especially if the tables are earthed.
Chris H
  • 2,591
  • 19
    The iPod Shuffles (except first generation) also use that kind of connector; I've used the MP3 player you're thinking of or at least a similar device. The data rate feels USB 1.0-ish. – mu is too short Oct 24 '20 at 05:01
  • @mu that seems reasonable, and not too bad if you don't make a habit of it. I've never used mine - I got it on a whim for next to nothing, and by the time I came to use it the battery wouldn't charge – Chris H Oct 24 '20 at 06:21
11
Why? Let us count the ways...
  • Ease of manufacture (stamped pieces, single-plane wiring)
  • robust (flat wiping contacts)
  • safe contact sequencing (ground/power first, signals last)
  • protected contacts
  • overall shielding
  • good signal integrity (defined impedance)
  • low cost
  • can be stacked (better backpanel density)
  • can be a circuit board (dongles, converters)
and perhaps most important...
  • USB adheres to a defined, open standard.
hacktastical
  • 53,912
  • 49
  • 152
  • I think that the power and ground pins (in a USB A connector pin 1 and 4) are longer and hence connect first so that the device is powered before the data lines are connected. Not sure whether this is to prevent voltage spikes on the data lines when connecting power later, or in order to give a simple controller the opportunity to pick up an initialization sequence right away. Either way, in order to power the device +5V as well as ground are connected first. – Peter - Reinstate Monica Oct 26 '20 at 15:02
  • if you connect the positive power and any of the data cables before the ground, current will shoot through the ESD protection diodes and explode them, and maybe other things on your board – BeB00 Oct 30 '20 at 00:04
It's not an effective use of space.
FourierFlux
  • 710
  • 19
