Thanks for your help on the previous question. I set up my wheatstone bridge to pins 2 and 3 of the amp. When I use a voltmeter, I see differences over the bridge as a function of resistor change. When I put my voltmeter on the output of the INA128, I see a constant voltage of ~100mv. I am supplying with 3V with the reference pin directed to ground. The voltage is 100mv even with NC at pins 2 and 3. I would have thought it should be at 0. Any advice would be appreciated.
user1883691
  • 117
INA128 has a minimum supply voltage of 4.5V.
You are attempting to use it at 3V. I'm not surprised it doesn't work at all.
This is on the first page of the datasheet. I strongly suggest you read the datasheet before designing a circuit.
markrages
  • 20,015
  • 60
  • 97
