I'm a total newbie in electronics, and just started venturing in home automation.
In Brazil there are many different types of tankless water heaters, especially for bathroom faucets and shower. Mine is a somewhat newer model with an LCD display and four buttons: SET, UP, DOWN and POWER.
My goal is to hardwire the UP and DOWN buttons to a dry contact (a SONOFF 4CH Pro) so I can remotely increase and decrease the temperature, much like what you'd want to achieve with an air conditioner. My wife (as most women) loves boiling hot showers, I don't.
I've roughly grasped the concept of NO and NC, and that I would need to wire the two cables coming from the terminals from those two buttons to the NO + COM of two channels in my SONOFF.
The problem is that by looking at the backside of the board, I can't see that second terminal.
Here is a large image of the front of the LCD display, and here's the backside.
The buttons are touch sensitive, and I can see the springs connected to single terminals (R5 103, R6 103, R7 103 and R8 103) as I look at the backside of the board (left side of the image), but I can't seem to figure out that second terminal.
I'm hoping that someone can enlighten me on this one. Cheers!
Edit: I opened up the panel just now and tested by touching both "R5 103" and "C1 223" with either points, one at a time. Every time I did, it would case the sensor to be activated. Any chance to get the same result from a relay?
