Kid car use a 12 volt batterie, that need to be charge.
We need to Open the front car motor cover and unplug the connector for the batterie and plug the charger direct to battery for charging
I would like to to like a real car charging station
External or the car
With a light red when need charging and green when the charge is done install on the car
And a male female plug in for charging
What would be the circuit
I did one with a relay, my issue is when I plug charger, relay go ON light go ON but when I unplug the charger the 12 volt battery keep the relay ON
Thanks
AGI2020
Five or ten turns of one of the charger wires round a reed switch capsule will make a current relay that responds to the charging current, so when the charge is finished or when it is unplugged it will respond instantly.
use the switch part of that in series with your existing relay.
schematic
