Hope someone can help me, I am really getting confused.
So I am just getting into electronics, and a project i would like to do is to make my own LED strip lighting for a workbench.
I understand that a 12V strip needs a constant 12V supply, and if the usage is 0.900A per strip / meter and I want 2 strips, I will need a minimum of 12V 1.8A supply. I also understand that I should increase the supply by 20% so as to not over tax the unit. So a good supply would be 12V 2.25A.
If I have a PSU that provides 12V 5A is this too much or is it safe as the LEDS will only draw what they need?
Thanks in advance
Ahmed Eshra
  • 432
  • 16
So long as the rated current of the power supply is higher than the current needed by the LED strips (or any device) you will be fine.
Devices only take as much current as they need. A good analogy for it is to think of current as a rope. You can't push it, just pull it. So devices will only pull what they need. The power supply won't push it into the devices.
Diatrix
  • 119
