I have designed and fabricated an electronic device. High level explanation for this device is as follows:
The device designed scans the environment for RFID tags and when a tag gets too close to the scanner it triggers and alarm and then sends out an SMS using the SIM800l module.
The device pulls at most 2.5A and is connected to 5V supply. The scanner device takes 5V while the SIM800l takes 3.8V. Therefore a buck converter was used to step down the voltage from 5V to 3.8V.
The power supply contains a variety of safety features such as Short circuit / Overload / Over voltage. The main supply also has a surge protector. Hence the plug outlet and therefore my device is safe from any sort of surges.
The scanner is connected to the SIM800l using Veroboard and some resistors. These resistors are used as a voltage converter. The scanner output 5V but the SIM800l needs 3.3V.
The entire project is encapsulated in a plastic housing. The circuitry (scanner and SIM800l) does not produce a lot of heat, in fact, it does not even feel warm after 14 days of testing continuously.
My question is therefore what else saftey measures should I employ if I want to take this product commercially?
JoeyB
  • 2,177
  • 17
  • 47
    If you want to sell it everywhere it will need UL and ISO certification, and FFC testing to verify EMI behavior. Else it has to be sold as a novelty with no special performance claims. –  Aug 07 '20 at 00:34
    @VTNCaGNtdDVNalUy I think you meant FCC - Federal Communications Commission. That's for the US, in other countries you'll have to abide by their standards bodies and rules. – Aaron Aug 07 '20 at 01:18
    What area? EU? UK? US? You'd think safe is safe, but the law thinks otherwise and you'll have to follow that if you go commercial. – Mast Aug 08 '20 at 05:46
  • For the EU (CE mark) a safety assessment is required for everything. I have a plastic serving tray that is CE marked. – Peter Smith Aug 08 '20 at 14:59
    I do apologize for not accepting any answers. This is due to the nature of these questions which allows for an open-ended solution that is not specific. Due to this, every answer posted is correct and helpful and it is hard to distinguish which one is best since each answer adds to the overall solution to my question. – JoeyB Aug 09 '20 at 20:26
6 Answers6
12
This device is an intentional radiator (it transmits RF) so it will be relatively expensive to get it certified for all jurisdictions. Safety is on top of that.
Your product may be otherwise well designed with what you think are good protections, but if a single-point failure can cause a fire or electrical shock then it may need to be modified. If every part that comes near the mains is plastered with listings and your design is decent it will be a lot easier/faster/cheaper. They don't care so much if your product is reliable or useful, the focus is solely on whether it can cause harm in one of a number of ways. For example, the plastic housing may need to be made of an appropriate resin with fire retardant additives to be approved, but certain fire retardant additives are banned in some jurisdictions.
So maybe decide where you want to try selling it and research which standards apply (often there are gray areas) and get ahold of copies of the relevant standards.
Spehro Pefhany
  • 397,265
  • 22
  • 337
  • 893
12
External Power
As I understand the design, you are using mains AC power (presumably 120V - 240V) to power a device with the power being converted using a module inside your device. That means you will need to pass some appropriately severe design rules and testing to protect both human safety (i.e., prevent shock from exposed mains wiring) and fire (higher voltage present = higher risk, including heat dissipation from the power converter).
Since your primary voltage is 5V DC, you should seriously consider use a "wall wart" to provide the 5V DC power. Those are readily available, already tested for safety by UL and other organizations, and very inexpensive. You may be able to use a USB charger - those are incredibly common - but you need to make sure that it can provide sufficient current to meet your needs.
Once you switch to an external power supply, the safety concerns are substantially reduced. You still have heat == fire concerns, but without any 120V (or higher) AC present in your box, electrical safety is pretty much resolved. 5V @ 3A just can't do that much damage. 120V at a tiny fraction of an A can kill.
As noted by others, there are a number of other factors besides electrical safety, potentially including:
  • Hazardous Materials - Not likely to be a factor here, except that you'll almost certainly end up with a California 65 Warning if you decide to sell this across the US including California. I'm not sure what, if anything does not get a California 65 Warning.
  • Radio Frequency Interference - FCC in the US, other agencies elsewhere. Anything which can emit radio frequency signals, which includes almost anything electronic but by definition anything with a WiFi or cellular or Bluetooth transmitter, will typically require some level of certification that it follows certain guidelines to prevent interference.
    You think you know it all until you ask someone else for their opinion and I am amazed by the feedback I have been given. This is truly an eye-opener! – JoeyB Aug 07 '20 at 16:36
Unless you plan to fund your entire venture on your own, I think this effort is somewhat misplaced. It's not where you need to be putting your effort or money right now to bring this to market.
Bringing the product to code or to standard should certainly be part of your business plan, but you should run with the assumption that this product can be brought to code by a person with the appropriate skill set. Your focus should probably be on a prototype that is sufficient to gather enough support to move it along to the "next step" (venture capital, angels, business loan, sell it or license it to a company in the arena), and potentially protecting IP.
That "next step" might well include code compliance, but it sounds like you're at too early a stage to merit attention to that area (though keep it in the back of your mind!). We call such an effort a "Minimum Viable Prototype"
Lastly, if you don't have a business plan, you should have a business plan. If the risk of a false start because of code noncompliance would be really troublesome (i.e., if it's of tremendous importance to get this right), then handling this from a position of inexperience is likely too risky, and your plan should include a consultant in the area.
Volker Siegel
  • 1,076
  • 26
Scott Seidman
  • 29,939
  • 44
  • 110
  • All the components used have been certified and FCC approved. All I did was integrate them. So in essence, once the scanner senses a tag it then sends a signal to send the SMS. The components are already been used for the purpose stated in the datasheet. Is there still a need for further certification? – JoeyB Aug 07 '20 at 14:21
    @Joey: I believe it is required. After all, it is possible to use certified and FCC approved components in ways which invalidate that certification or in ways which create hazards. – RedGrittyBrick Aug 07 '20 at 14:55
    Yes. Using certified/listed/approved components makes things easier, but does not eliminate the need for testing and certification. – Spehro Pefhany Aug 07 '20 at 15:26
    The only way to avoid FCC approval is to sell your product without the RFID component and tell your end users to install one they bought themselves. This is how a some hobby radio control transmitters are sold: they have a somewhat standard module bay and users are expected to buy and install their own radio modules. It is the module manufacturers that need FCC approval. – slebetman Aug 09 '20 at 03:24
the minimum safety requirements for your type of equipment, that apply in Europe and most parts of the world are covered by the IEC 62368-1 standard "Audio/video, information and communication technology equipment. Safety requirements" (previously it was the IEC 60950-1). This will be what the certification for electrical safety will be based on for assesing your equipment.
citizen
  • 2,626
  • 18
Hire someone experienced to get it through listing
That is, UL listing and FCC cert, as well as CE, RoHS etc. This is a very difficult area fraught with tricks and traps for the inexperienced. They’re not trying to fool people; they just haven’t done a very good job making the process accessible to hobby builders. You cannot solo this; those who have tried have been eaten by the system.
Keep in mind a big part of it is your factory manufacturing the items. You need a factory the listing agency has a relationship with. Random Chinese factory, or even random American one, may not be up to snuff. That’s especially true if your factory generally does limited run stuff e.g. for industrial controls, and doesn’t do consumer products.
It works better if your expert is in the loop starting early
A lot of people think this compliance is a last-minute bolt-on; one of the boxes you tick right before production.
That’s not the best idea, especially when you’re dealing with RF. You are better off having the Code requirements inform your design choices from the moment your idea hits the back of the napkin.
Watch what your competitors are doing
A lot of people see their competitors swerve out of their way to take a particular approach. They think “Well that is weak, I can do better than that!”
Then, as you get into the process, you find out there’s a reason they took that approach. The reason relates to the product safety standards or Code requirements everyone must follow.
For instance there’s a little detail that UL must approve both your device and its installation instructions. Home power monitoring systems like Sense place their “box”, its power supply and all the current transformers entirely inside the service panel, with nothing but a WiFi antenna sticking out. Any half-competent EE can get the idea to mount the box externally with an atttractive, interactive display, and just run the CT pigtails into the panel. But that cannot be installed legally, so UL will never approve it.
UL needs electrical equipment to meet published safety standards (the UL White Book). But UL also approves the labeling and instructions as part of the UL Listing (which is why some instructions are so ghastly; they used tired and true boilerplate text). UL needs to see that the installation procedure is compatible with the Electrical Codes (CEC for Canada and El NEC for most of the rest of North America, for instance). Your instructions can't tell people to violate Code.
  • In US parlance .. "The Code" refers to the National Electrical Code (NEC), NFPA 70. Apparently you can get free access to it here https://www.nfpa.org/codes-and-standards/all-codes-and-standards/list-of-codes-and-standards/detail?code=70 the sign up process is a pina. – Alan Perry Aug 08 '20 at 22:30
  • Thank you. I live a country were these processes take a minimum of 2 years, especially if you not associated with a well known company. This is why is so frustrating for people like myself to make new devices. Because we just get stone walled and the cost of getting it approved is 10 times more than the product I made. It's is so sad that we generally don't even bother because the system is designed around big companies and not up coming engineers that want to them things themselves. So there's no place for us in this country. – JoeyB Aug 09 '20 at 13:31
Again, if you are alone in your venture, you need to make sure you are immune to false positives, since you will most likely be required by FCC to accept external interference. Code acceptance won't include this. if you are cheapest on the market, but don't work as is expected...
maxnort
  • What are false positives? – JoeyB Aug 09 '20 at 13:33
  • I think False Positives here refers to something other than the expected RFID tags causing a "read" - either RFID tags of a different type (e.g., trying to read RFID tags on boxes and someone's wallet has an unrelated RFID tag setting it off) or interference from other things (e.g., walk by with a smartphone and Bluetooth/cellular/WiFi sets it off). – manassehkatz-Moving 2 Codidact Mar 05 '21 at 16:38
