Given a SystemVerilog design modeling an ASIC, how can I enforce the rule that all logic/reg elements that are used in flip-flops should not be initialized to a certain value? Is there a directive that I can use in my code that would prevent this?
Here's an example:
module asic (...);
    logic a;    // this is fine
    // logic a = 1;    // but this is not fine
reg b = 1;  // this is fine since it is not a flip-flop
always @(posedge clk, posedge rst)
if (rst)
    a <= 0;
else if (b)
    a <= ~a;
endmodule
I think a check like this would be really helpful in ensuring that all registers in the ASIC design have a reset. The tools I use are Verilator (for linting and simulation) and Yosys (for synthesis), but I haven't been able to find a related option in their documentation.
Inline initialization is not good, even for the b signal. A commercial tool I use for ASIC synthesis ignores those initializations and throws warnings.
If b is a constant, the below would be better (still not ideal).
logic b;
assign b = 1;
I experienced failures in formal equivalence checking (RTL vs. synthesis netlist) as well, so I avoid inline initializations in design.
  • I'm thinking you can't tell me, but could you tell me which tool you were using so I could do some research into how it checks for those initializations? I can't use it myself since I have to use open-source tools since the software I wrote that uses it is used in academia. – norandomtechie Jul 24 '20 at 21:34
  • @norandomtechie It was Synopsys Design Compiler. –  Jul 24 '20 at 22:29
  • Is Synopsys Design Compiler accepting assignment of logic inside initial block to synthesis ??? – Mitu Raj Nov 14 '20 at 08:31
    @MituRaj No. –  Nov 14 '20 at 14:44
