I want to use the INA138 as a current sensing amplifier but its symbol is not available in Ltspice so I downloaded the .lib File from https://www.ti.com/lit/zip/sbom140 here.
I then opened the file in Ltspice and clicked on the (.subckt INA138 + - Vs GND OUT) name of the component besides the subckt title and thus right clicked on it to create a symbol. I updated the model file for the symbol and saved it but when I use it I am getting an error stating
"Could not open the library file"
If anybody knows how to solve this please respond. Thank You
SAM1
  • Creating custom symbols hard-codes the path into the symbol. Edit the .asy file with a text editor and delete the line SYMATTR ModelFile .... Then make sure your library resides in a correct location before using .lib /path/to/library.sub. – a concerned citizen Jul 01 '20 at 23:22
  • @aconcernedcitizen tried. Doesn't work. – SAM1 Jul 02 '20 at 04:00
    You already have a very similar question here. Does the very detailed answer provide any clues to you? Answer which you haven't checked. – a concerned citizen Jul 02 '20 at 06:42
