I'm trying to understand this schematics section related with a micro-usb connection:
I have three questions:
- Why are the resistors with 0R? Is this a convention for a particular value?
- Which electronic component is F1?
- The same as 2 but for FB1.
That's a very common notation: R is for "resistor", and is placed where the decimal point in the component value in ohm would be (because Ω was hard to produce back in the day). This is a 0 Ω resistor – in case you analyze your device and figure out later that a USB-compliant termination resistor is actually necessary.
What is the schematic symbol for resettable fuses?
Which electronic component is FB1?
https://electronics.stackexchange.com/search?q=schematic+symbol+FB
