The short answer to ‘how’: contact fab vendors and describe what your requirements are to figure out what services you will need. They will walk you through the process and identify your costs for budgeting.
Who are these companies? The best-known wafer fabs are TSMC and GlobalFoundries. Samsung also offers this service. There are others that specialize in smaller wafers/older processes, like SMIC in China.
A lower-cost way to do that is to put your die on a ‘shuttle’ - a multi-project wafer - to get some sample chips for testing. The majors provide this service, as well as smaller outfits like Tower Semiconductor, UMC, and others.
Fab companies provide various levels of service depending on your needs and how much money you have to spend. Unsurprisingly, part of the process of engaging a multinational like TSMC is qualifying your business. Not only will this determine if they will take your order, but your pricing and delivery as well.
In your case doing your first ASIC you might need to work with a third-party provider who can do all the back-end work for you vs. working directly with a fab. Fabs can identify appropriate partners who do that service. I've worked with several; a well-known one is Socionext.
What’s it going to cost? The main up-front cost is the mask set. Three factors influence this: die size, number of layers, and process node. For a small, mixed-signal chip like an Ethernet PHY, it could use an older process like 180 or 120nm. Ballpark for such a mask set would be about $75-150k.
The next fixed expense is test fixtures and test development. This can run to multiple tens of thousands. Add to that fixtures for accelerated-life and ESD/latchup testing.
You must also do a package. Even if you choose a standard type, it needs to be laid out with an appropriate bonding scheme for your die.
Your Ethernet PHY example is somewhat more complicated, as it includes a mixed-signal hard macro block, that is, the PHY itself. Most people license these things from third parties, for good reason: designing a PHY is a specialty skill, and is considerably more expensive to qualify in silicon than a logic block. If you intend to design your own PHY, expect needing access to some expensive front-end-design tools, and later, access to expensive test gear to qualify your PHY, and hiring an expert to develop and run your tests.
There’s other expenses I’m certainly missing here but you get the point: expect up-front costs in the multiple hundreds of thousands even before you get your first packaged part.
Different companies can negotiate pricing. In one model, they can bury some of the fixed expense by increasing the cost of the delivered IC, but they will pressure you to take agreed-upon quantities.
Finally, if your design is of good quality with unique differentiation, you could possibly sell or license it to an existing company in that market space and defray some of your costs. But for it to have value, it needs to be proven in silicon.
