I'm an experienced board designer, having designed 100+ boards over the past decade, and I have yet to hear a good answer for why the PCB part number is traditionally on an external copper layer, and the PCBA part number is on a silkscreen layer. To me copper is always "sacred" and should not have anything unnecessary on it, as this can screw up voltage isolation, RF performance, etc. But for some reason designs tend to have the bare PCB part number in copper instead of silkscreen. Why?
Copper etching is a very early step in the PCB manufacturing process. Etching the board number on the copper layer allows identification of the board at all subsequent stages. To omit it would risk confusion due to lack of a board identifier.
- 175,532
- 13
- 190
- 404
2Okay thats an interesting point, didn't think of that, but then again; why would you need to identify the PCB at later stages in production? all the places I've worked the production was so streamlined that different pcb's didn't get mixed in a way so that it would make sense to mark them. – Jun 08 '20 at 17:26
5@Vinzent no quality control between steps? Quality control is, as far as I know, at least partially manual process in many factories, and where are people, there are mix-ups. – Mołot Jun 09 '20 at 08:39
5@Vinzent I suspect the practice started – and was much more important – when production was nowhere as streamlined as it is now. Think stacks of boards waiting for the next step. – TripeHound Jun 09 '20 at 10:53
1@TripeHound Absolutely. I've worked briefly in a prototype-house and batches under 50 often weren't automatically tested at all. All manual labour, and manual labour is never as streamlined as you want it to be. Especially back then (roughly a decade ago). The further back you go in time, the more important it was. – Mast Jun 10 '20 at 11:30
1Rob: "What are you doing up?" Bucky Katt: "I'm on mouse patrol." Rob: "But we don't have mice." Bucky Katt: "We don't have mice, *because, I do mouse patrol!"* The factories don't have problems like that, possibly because they label the boards first step. – Harper - Reinstate Monica Jun 10 '20 at 17:46
I do a lot of multi-layer boards and the board reference number plus layer name gets put into the copper on all layers plus, there is a drawing accompanying the job that states the layer stack up to make sure that the bare PCB is made correctly. No chance of screw ups. If there is enough room on the PCB (say with 4 inner layers), there will be 4 distinct places on the board that if you shine a strong light through you will see the internal numbers. You can therefore inspect the layer stack to see it has been built correctly.
I'm not saying that there aren't other reasons but these are mine.
- 456,226
- 28
- 367
- 807
2This is a good response and I totally agree that it is extremely necessary to have both board reference number and the layer stack up number, specially on very complex multi-layer double-reflow boards. In the company were I worked lastly, the board design rules provided to have a lot of drawing templates according board dimensions, scoring and for their panelization; and all these templates had very rigid rules providing the location of board reference number and layer stack up number. Having a set of drawing templates greatly helps the pcb designer. – barrow Jun 08 '20 at 22:51
3+1 for this. By the same token, you should also have registration targets on all layers too, again as a quick check that the multilayer assembly went together correctly. – Graham Jun 09 '20 at 12:03
My company started designing PC boards in the early '80s. These were single-sided boards with NO solder mask or silkscreen. The only permanent location for the board number and company information was on the solder-side, in copper.
Even though we now design double-sided boards with solder mask and silkscreen, we still include board number and company info on the copper-side layer. We also include that information on the component-side layer as well, room permitting. And the silkscreen layer, of course.
- 23,792
- 2
- 38
- 70
I asked this same question years ago earlier in my career. The answer I got was that the copper layer usage for the board number was more permanent than silkscreen. In other words it was harder for someone to scrape off the copper number text than it was for someone to remove the silkscreen.
Some of the intention of more permanent board markings, I was told, was to make it easier to see if some unauthorized person or company was modifying your hardware somehow and selling it as their own product. A scraped off copper area on the board would be much more obvious than a silkscreen that was removed by some solvent.
- 57,328
- 3
- 71
- 138
That was a possible reason. But who would do that nowadays?. Traditions die hard. ;) – Fredled Jun 08 '20 at 22:58
It's better to have the BOM sticker (with revision) on a sticker, never know if you are going to have two alternatives :)
If you are cheap you might skip the silk and have the PN on copper.
- 3,295
- 1
- 4
- 23
4I can't tell you how many times I've seen stickers just fall off, though. From boards in industrial machines, to computers and home appliances, the stickers just aren't reliable. It can be due to high heat, extreme low temperatures, age, bad stickum, spillage of solvents or lubricants, or placement over components, they really aren't as reliable as other methods. Stickers are useful, but shouldn't be the sole source for identification. – computercarguy Jun 09 '20 at 19:25
There certainly are sticker materials that would be reliable for applications like computers and home appliances and there are standard tests to verify it. On cheap boards the BOM stickers would be of the cheapest type though and only expected to last through the manufacturing process to not add cent to BOM cost. Sometimes stickers are safety critical and expected to last even in various industrial applications. – Ralph Jun 10 '20 at 20:08
..but I usually make a square in the silkscreen, the size of the label, to mark where to put the sticky label.
– Jun 08 '20 at 17:19
