enter image description here[enter image description here] here is the image of the simulation [1]This is my MatLab code and I am trying to take a plot of what I have done, but when I run the code the plots are all empty
Do you know how I can fix it?
clear
clc
steptime= 0.0001;
t=[10;10;10];
% position parameters
% p=[x_initial y_initial z_initial]
p_0= [0.999;0.999;0.999];
p_env=[1;1;1];
p_desire=[1.1;1.1;1.1];
% Parameters
m = 0.5;
K_E=1000;
K_V=5;
K_P=3;
k_e=K_E*eye(3);
k_v=K_V*eye(3);
k_p=K_P*eye(3);
f_e = (k_e*p_0) - (k_e*p_env);
sim('Force_Control_Finger')
subplot(2,1,1)
plot(t,p_0)
xlabel('time[s]')
ylabel('position')
subplot(2,1,2)
plot(t,f_e)
xlabel('time[s]')
ylabel('f_e[N]')
figure
plot(t,f_e)
xlabel('time[s]')
ylabel('f_e[N]')
Voltage Spike
  • 82,181
  • 41
  • 84
  • 220
Ha D
The problem is you are plotting a single point and equally multiple single points on top of each other. By default Matlab suppresses points which makes sense when you are doing a line plot of continually varying data but not so much when it is a single point
your time array is a 3 entry array of the same time, 10.
t=[10;10;10]
t =
    10
    10
    10
Now if you make a slight edit to the plot command:
plot(t,p_0,'k*','MarkerSize',20)
ie plot in black, markers as an astrisk and make the marker large, this is what you have. You will have three stars over each other due to the same data being asked to be plotted, three times:
p_0
p_0 =
    0.9990
    0.9990
    0.9990
2nd
How to fix? well what are you trying to do because this is doing exactly what it should but without additional info we can't help
--edit-- so I recreated your model and changed the key variables to single dimension
p_0= 0.999 p_env=1 p_desire=1.1
  • Thanks a lot for your complete answer.I am trying to do force control for my finger robot, and it seems that the Simulink simulation does not work in matlab, cause when I do not define the t and f_e in matlab file , the code does not work and asks me to define these two. – Ha D Jun 07 '20 at 17:08
  • where is t being used in the simulink file? Typically there should be a Time vector produced by the simulink file. Likewise where is f_e being used in the model? a constant block? gain etc? what you should have is a to_workspace block to output the results of your time-varying simulation. Within Simulink, can you attach a scope to the node you are attempting to plot via matlab? –  Jun 07 '20 at 17:21
  • I already added the snapshot of my Simulink simulation to my question. could you please take a look at it? – Ha D Jun 07 '20 at 17:23
  • I see you have attached the block overview in the original post. On the face of it, it looks valid. What doesn't make sense is why you said it complains if you don't pre-declare "t" since t is the output of the clock. What solver are you ussing? is it a continuous solver? this could be a refinement issue. Try putting a scope at the same places as those to_workspaces to see what they look like –  Jun 07 '20 at 17:23
  • the solver is fixed-step type and ode5(Dormant_Prince) – Ha D Jun 07 '20 at 17:28
  • I added scope and the result has been added to the original post. – Ha D Jun 07 '20 at 17:34
  • and it is still my question that why the .m file asks me to define f_e and the t where both of them are already defined at Simulink simulation !!!! – Ha D Jun 07 '20 at 17:37
Add figure to create a figure window before the subplots, you need to create two figure windows
 figure
 subplot(2,1,1)
Your data is three points all in the same place so the first plot is probably not Change t to t = 1:3 Or t = [9;10;11]
Voltage Spike
  • 82,181
  • 41
  • 84
  • 220
  • Hi, I wonder how this kind of a question is accepted as an EE.SE question? Some of my questions, which were far more related to EE w.r.t to this one to me, were labeled as off-topic before. – muyustan Jun 07 '20 at 16:30
  • you do not need to create two figure windows. The 1st plot command will create a figure, any additional figures to isolate plots will need figure called. The OP stated their intent is two figures and their code will do this (since there is an explicit call to figure later). Likewise a lack of a figure call does not answer why a plot window would be "blank". –  Jun 07 '20 at 16:58
  • @muystan which questions? – Voltage Spike Jun 07 '20 at 22:15
