If we have a gain of 10 for inverting configuration of an op amp and we increase the amplitude of the input signal, why is the output of my circuit not continuously producing 10 times amplification?
Asked
Active
Viewed 72 times
-1
4If you want a useful answer please provide a schematic, the nature of your input signal (e.g. waveshape, frequency, amplitude), and your method of measuring the output signal. With this information, we should be able to help you understand what you are observing. – Barry Jun 03 '20 at 23:25
1Related: canonical question about the limitations of the 741 op amp: https://electronics.stackexchange.com/questions/304521/reasons-not-to-use-a-741-op-amp – MarkU Jun 03 '20 at 23:27
One possibly is slew rate limiting. Another is clipping as the outputs approach the supply rails. A third possibility is current limiting because your load is too heavy, either extra loading on the output or simply because the feedback resistor is too low in value.
Spehro Pefhany
- 397,265
- 22
- 337
- 893
