I've been working on a solid state tesla coil project.
I have a question about the driver circuit to drive pulse transformer.
If I input a modulated or interrupted waveform on the input of the transistor base pins, can this transistor arrangment drive the gate drive transformer properly?
MicroservicesOnDDD
  • 2,790
  • 14
  • 51
can these transistors arrangment drive the gate drive transformer properly
Look at this: -
If \$R_L\$ represents your transformer primary then the average voltage it receives will be half of Vcc or 6 volts. You MUST NOT allow this to happen with any transformer. To remedy this put a capacitor in series with the coil to force the average voltage on the primary to be 0 volts.
Andy aka
  • 456,226
  • 28
  • 367
  • 807
  • Thank you very much mate – Mahesh Mahesh Apr 18 '20 at 12:23
  • "Thanks" around here is normally seen as up-voting of answers and then finally, when you are satisfied that you have the best answer, you formally accept said answer. I mention this because I see you have asked 5 questions now and you might want to address this before it becomes too much of a hurdle @MaheshMahesh – Andy aka Apr 18 '20 at 12:31
Perhaps adding a capacitor can solve your problem.
schematic
Marko Buršič
  • 23,961
  • 20
  • 33
  • Okey adding a capacitor should do the job but im curious that,doesnt the capacitor will change the waveform like im planing to have two mode on my tesla coil one is musical interupter and another one is burst mode so is it gonna interupt with my signal? – Mahesh Mahesh Apr 19 '20 at 03:15
  • The gate driver circuit shall output square pulses, it doesn't matter what kind of modulation is used. The problem is, that not always this is acheived. This capacitor coupled / decoupled (on secondary) circuit is challenging, you'd better to search in HVorg forum, or you simply change the driving circuit to full bridge. – Marko Buršič Apr 19 '20 at 06:28
  • Okey i will ask on that forum,but if i used a full bridge i need a gate driver for that and im not a veteren on electronics i know basic fundamentals about it and im still learning so thats a problem considering the lack of knowledge,but i will research and ask people who have more experience on this field,anyways thank you very much for your suggestion – Mahesh Mahesh Apr 19 '20 at 06:34
