The boolean function I want to convert is: F = xy' + yz'
I will first convert it to canonical form:
F = xy' + yz' ------> (1)
= xy'(z + z') + (x + x')yz'
= xy'z + xy'z' + xyz' + x'yz'
= Σ(2, 4, 5, 6) = π(0, 1, 3, 7)
Now, F' = π(2, 4, 5, 6) (Is this statement correct, why not?)
= (x + y' + z)(x' + y + z)(x' + y + z')(x' + y' + z) ------> (2)
I thought I had converted the function to POS form, but when I checked the truth tables for (1) and (2), they are the complete opposite. Truth table for 1 Truth table for 2
Why is this incorrect? According to this answer, I'll have to complement the input function twice to convert to POS form. But this seems very counter-intuitive because if I complement a function twice, will I not get back the original function?
    This explains it far more thoroughly. https://electronics.stackexchange.com/questions/9817/how-to-convert-an-expression-from-sop-to-pos-and-back-in-boolean-algebra – nickalh Mar 10 '23 at 01:40
No, you don't simply complement twice.
You complement once, then use DeMorgan's theorem and the distributive property to get a SOP form for \$\overline{F}\$. Complement again, and use DeMorgan's theorem again to finally get the POS form.
In a sense, you do have the original equation back again because the result is logically equivalent to the original equation.
Elliot Alderson
  • 31,521
  • 30
  • 67
    Clarification- you do ultimately complement twice, but not just complement twice, also use each complement to apply DeMorgan's law first then again. – nickalh Mar 09 '23 at 19:05
