i bought an expensive desk lamp from the US called Lumiy Lightsblade 1500s, i lost the power adapter, so my questions are as you are electrical engineers: 1) can i use it in israel (The standard voltage is 230 V and the standard frequency is 50 Hz.) ? does it lose its peak because the countries difference? 2) what power adapter should i seek for when buying?
Asked
Active
Viewed 306 times
12V DC 2A, as it says on the label, but make sure the new adapter has the correct plug. Easiest way would be to buy a replacement from teh manufacturer. – Jan 28 '20 at 15:02
2If you lost the power adapter..... you can't use it anywhere. If you are seeking product recommendations for a replacement, that subject is normally off-topic for this site. – Andy aka Jan 28 '20 at 15:12
Yes, you can use it in your country.
Specs allow you to use any power adapter which outputs 12 VDC and can supply 2 A or more current. You need to buy a correct plug that can work with your light.
Whiskeyjack
- 8,286
- 9
- 58
- 99
