I am attempting to build a really cool thing (at least I think).
The goal is to build an arc lighter that I can shake to charge (kinetic power).
It's a circuit that combines an arc lighter circuit with a 3.7V input, a supercapacitor to power it instead of a lipo battery, and the power system of one of those "shake-to-charge" flashlights from the '90s. Here's what those flashlights looked like:
I'm really only an electronics hobbyist and have never really designed a circuit board before, but I've been learning EasyEDA and have gotten decently proficient.
As far as I know, I need to combine the arc lighter circuit like this one:
Increase Arc Lighter Spark Gap
and also make sure I choose a super-cap with enough storage to fire the spark for at least a few seconds if not longer.
My question to you guys, among others, is: Is this feasible, and if so, where do you suggest I start?
Any and all advice is valued and I am so grateful to have found a community where electronics wisdom exists and I can ask questions. Thanks!
edit: I did some power requirement math and put it down below. So far you guys have been so helpful. Thanks for everyone who’s helping in any way!
I found a brand of arc lighter that put their tech specs in the FAQ on their site and figured I'd start with that: https://www.arclighter.com/arclighter-faq
“[the lighter] …can light 90 times on a single charge based on 8 seconds per light.”
8 seconds per light x 90 lights = 720 seconds of arc firing per charge
“What are some of the charging characteristics of the [product name]? Nominal Capacity: 450mAh Input: 3.7V Output: 6A“
450mAh@3.7V / 720 seconds
0.625 mAh per second @ 3.7V
Converted 3.7V 450mAh to Joules: with (mAh x voltage x 3.6 = Joules of energy)
~6000 J of energy per battery
6000 J / 720 seconds
= 8.3J/second while firing the arc (for this brand of lighter)
I have to keep in mind I will not be using lithium batteries and instead using supercaps. I have no idea if there are any negative ramifications other than not needing lipo charging circuitry, and I can instead use a Zener Diode to prevent capacitor overcharging.
