-2
I would like to connect a bell to a transformer as part of a project im working on. The only thing i cannot seem to find an answer to is wether or not the output from a transformer is fixed:
Say i was to plug a 24v 330ma step-down transformer into the bell (which operates at 24v 30ma), what would happen?:
A: The transformer overprovides, the bell takes everthing it's given and burns itself out.
B: Only the required amount of current is taken by the bell and everthing operates as normal.
C: Something else (?).
Anaxion
B, power supply is capable of providing more amps than the load requires.
Justme
  • 147,557
  • 113
  • 291
B is correct.
Thought experiment:
There's a (much bigger) transformer feeding your house. What happens if you switch off everything else except one little light bulb?
A: The transformer over-provides, the lightbulb takes everthing it's given and burns itself out.
B: Only the required amount of current is taken by the lightbulb and everything operates as normal.
C: The supply transformer explodes.
Transistor
  • 175,532
  • 13
  • 190
  • 404
