I'm confused about how to understand battery capacity by its ratings. I though I understood Amp-Hours, as a nominal rating where they usually specified a period of time where that rating was approximately valid. So below is the rating a particular batter, where nominal capacity for 20 hours rate-Ah is stated as 74 and the 10 rate-Ah . I assumed means that for 20 hours it can sustain the 74 Amp-hour rating, so I would expect that the amp-hour rating for 10 hours would be as high or higher but it's 65. So i'm not sure it means what I thought it means. So does it mean that I can operate the battery for 20 hours at 74 Ah /20 h = 3.7 amps, but if I use it for 10 hours, then it can run at 65 Ah /10 h = 6.5 amps for each hour? Why this reasoning doesn't seem quite right to me is that I thought the Amp-hour rating was high if you specify shorter periods of time.
Below is an example of a battery rating. And the link to the published chart.
| Volts| PHCA | CCW | HCA | MCA | Nominal Capacity | Reserve Cap. |
| | 5 sec| | | | 20 HR Rate-Ah | 10 Hr Rate-Ah | in Minutes |
| 12 | 1750 | 950 | 1350| 1070| 74 | 65 | 145 |
I think this might help
– muyustan Dec 06 '19 at 20:29
