I'm going through the 'Electrical Characteristics' section of datasheet of PIC24EP128GP206 to find out minimum and maximum voltages and currents specific to GPIO pins.
While doing so, I came across the terms IOL, IOH in the following section:
What do the IOL, IOH currents exactly represent? Are these the sourcing / sinking currents associated with the output pins? Why is the IOH limit is mentioned negative?
zeuschyant8
  • 165
It's just a convention thing. Normally currents into the device (supply currents etc.) are attributed positive values therefore, currents from chip pins are given a negative sign.
  • IOL is the current into the pin (sinking) when the pin has a logic level of zero.
  • IOH is the current from the pin (sourcing) when the pin has a logic level of one.
All the data in the table in the question refer to the pins being outputs (3rd column of table).
Andy aka
  • 456,226
  • 28
  • 367
  • 807
For a VOH test, the GPIO must act as a constant-current load, and for a VOL test, the GPIO must act as a constant-current source. Before any pin is connected, the GPIO should be set to source or sink the desired current, then, once the pin under test has been connected a voltage measurement should be performed.
thats how they are calculated from the output driver resistance:
VOH = VCC – IOH * ROH
VOL = IOL * ROL
Eng Sam
  • 479
