Are external pull-up resistors required on RN4870/71 for pins like "P1_1"? The datasheet mentions D I/O pins being "pulled-high", is it pulled high with internal resistors or programmatically from the microcontroller it's connected to or are external pullup resistors required?
Asked
Active
Viewed 41 times
According to datasheet pg 11, there is a pull-up resistance of ~50kΩ. If the pins are naturally pulled high, it must be enabled by default. However, be careful, 50kΩ is a pretty weak pull up, you may need to add in a smaller external resistor if pull up speed is a critical concern (Low pass formed with parasitic capacitance and pull-up resistance, bigger R, larger tau, slower response time).
Yet Another Michael
- 2,351
- 1
- 11
- 19
