I would like to know if I used a circular polarized (RHCP) antenna inside a metal container as show in the configuration below will it reduce the dead zones, as compared to a linear polarized antenna?
From the research I have done when RHCP EM wave reflects of the metal surface it will become LHCP. It further went onto say that only when two RHCP EM waves "collide" will there exist dead zones due to destructive interference, where as if an RHCP collides with an LHCP then it can reduce these dead zones.
JoeyB
  • 2,177
  • 17
  • 47
    @user24368 - yes. It is a linear polarised antenna – JoeyB Sep 06 '19 at 12:58
  • I answered below with the assumption that the enclosure is large enough for the waves to "exist" in. The RFID tag made me think that maybe the box is much smaller than the wavelength so that you actually want a near field coupling. – user24368 Sep 06 '19 at 15:20
I'm not 100% certain, but I would say "no, transmitting circular polarization inside conductive enclosure does not reduce the amount of areas where linearly polarized field is zero compared to linearly polarized transmit antenna". Here is my reasoning and assumptions for you to check:
  1. The transmitting RHCP antenna can be divided into to orthogonal LP antennas with \$90^\circ\$ phase shift.
  2. These two antennas could be electric dipoles, even though the tag RFID suggests that an inductive coupling could take place. For traveling waves the magnetic field just tags along.
  3. Adding a second transmit antenna does not increase the total power transmitted.
  4. I assume that the box is electrically large (not much smaller than the wavelength) so that the waves "fit in" your box.
  5. The waves from the two LP antennas travel originally independently of each others, but can, due to reflections, happen to have same polarization (direction of electric field).
  6. The destructive interference happens when two reflections meet at the same point with same polarization but with opposite phase.
  7. The probability of this destructive interference is not affected by how many "original" transmit antennas you have in your system. Thus the dead zones happen just as often with both RHCP and LP polarizations.
user24368
  • 743
