I am looking at installing an electric towel radiator. The heating element is 200W.
Dose that mean that it would both:
- Use 200W of electricity.
- Provide 200W of heat output to the room.
Yes, electric heaters are basically a resistor.
A resistor converts electric energy into heat, it does that with 100% efficiency.
That might sound weird but think about it this way: if a resistor was 90% efficient, where would the 10% "lost" power go?
Nearly all not 100% efficient devices lose the wasted energy as heat. Generating heat is the sole purpose of a (resistor) heater. So even if the heater was only 90% effcient, that 10% would still be heat, making the efficiency 100%.
So indeed the heater consumes 200 W (when it is in operation) and it will then also emit 200 W of heat.
Yes (maybe a couple of watts more for electrical losses in the cabling from the energy meter) and yes (unless there are losses through the wall to the outside world). Of course it may only produce 95% of the rated output - nothing is perfect of course and, it may indeed produce 105% of the rated labelled power.
- use 200w of electricity
Yes. It would consume 200 W of electrical power.
- provide 200w of heat output to the room ?
It would give of 200 W in the form of heat.
'W' for watt, 'V' for volt, 'A' for ampere.
Possibly the most universal law in physics, even before the constant speed of light, is conservation of energy. Energy in + energy stored = energy out. So if there's 100W going in, and there's not a significant amount of energy being stored, then energy in = energy out. Always. Every time. And not just heaters -- lights, refrigerators, light bulbs*, motors, the Starship Enterprise**, etc.
If there's 100W going into the room, and it's not coming out in the form of light or radio waves or mechanical energy (or, presumably, subspace beacons in the case of the Enterprise), then it's going to heat up the room. Period. End of story. (And, sadly, it's why perpetual motion machines don't work).
Which is a really long way of saying that, yes, your 100W heater will consume as much power is it gives you in heat. And if it doesn't quite match its ratings and it consumes more power, then it'll deliver more heat, and visa-versa if it consumes less power.
* Confusing "100W equivalent" ratings on LED and CFL bulbs notwithstanding -- I'm talking about real energy.
** Although the Starship Enterprise won't fit well into a room that is appropriate for a 100W heater, and it usually comes with a lot of stored energy in the form of antimatter.
it's not coming out in the form of light or radio waves or mechanical energy - well, in the ideal world it wouldn't. In the real world with non-zero self-capacitance/inductance of the elements and EM radiation from heating happening spontaneously in a way we can't prevent - the energy does indeed leak.
Aug 28 '19 at 21:29
Heat is the easiest thing to make. In fact it's the ultimate destination of virtually all energy conversion, because of how entropy works.
Every watt ends up turning into heat, or rarely, light. For instance a 100W incandescent makes about 98 watts of heat, and 2 watts of luminous light, which turns into heat after it hits wall surfaces.
A 15 watt (100W equivalent) LED makes 13 watts of heat and 2 watts of light.
One of my running jokes is that some people like to build heaters out of resistors, I like to build them out of Bitcoin miners. The electricity bill and useful heat will be the same either way, only one of them also gives you bitcoin.
So whether your towel heater computes Bitcoin or not, the answer is, 200W in, 200W out. It's not going anywhere else.
To add to the existing answers, your radiator is likely to have a thermostat to control the radiator temperature (not the room temperature), so the average power may be somewhat less than 200W.
From a reputable magazine that ought to know better, in the debate about which is cheaper to run: electric fan heaters or electric oil-filled heaters, the following:
Blockquote Oil heaters also have good heat retention. So, in contrast to a fan heater, when you switch an oil heater off, it takes a while to cool the oil down. This means even when it’s turned off the heater is still giving off heat, further cutting your energy costs. Blockquote
Follow The Science!!
