I am new to electronics and I am wondering how can I use my Vcc to produce a short single pulse.
brhans
  • 14,723
  • 35
  • 51
Jeffers
  • 33
Depending on your definition of short, and close, a single cap and resistor can do the job:
schematic
You can play with C1 and R1 to achieve the desired shape.
Vladimir Cravero
  • 16,395
  • 39
  • 73
    Maybe it is better to add that this circuit produces a positive pulse (+Vcc) when power is applied, but a negative one (up to -Vcc) when it is removed, which may cause issues to the circuit after this. In this case, adding a diode (anode to ground, cathode to PULSE pin) can solve the issue – frarugi87 Aug 07 '19 at 13:11
Try using a 555 IC in the monostable configuration, with this circuit you will be able to drive small loads, e.g., LEDs and logic circuits. Take a look at 555 IC It will give a response like this one
wikipedia on the 555 monostable circuit response
and the circuit is this one
where you should keep the trigger pin high (above \$V_{CC}/3\$) until the moment you want the pulse, at this time you should send a 0V signal to it, this circuit would do it:
schematic
jDAQ
  • 2,597
  • 19
