I recently bought a Transformer so that I can make an ionic lifter but it has a max 30 amp output and I’m sure that is way too much for what I need plus Since I have this plugged straight into the wall I’ll definitely need an ac to dc rectifier which at most goes to about 5 amps So my question is how can I reduce the output amps so that I don’t mess up this rectifier as soon as I get it.
Btw the transformer is a 3000W YaeCCC Auto Transformer
MasterJ
Inrush Current Limiters (ICL) | Circuit Protection | DigiKey https://www.digikey.com/products/en/circuit.../inrush-current-limiters-icl/1... CL, Active, 10 Ohms, ±25%, 5A, 180 mOhms, 0.770" (19.56mm), 0.328" (8.33mm), UL. SL22 2R515 Datasheet, SL22 2R515 - Ametherm, 570-1047-ND.
TJJS
  • 13
    Tom, the OP is clearly struggling with basic theory. If you are recommending a device then you need to explain why you think this is a good solution to "reduce the output amps" and where it would be wired into the transformer. In any case, the link is broken. – Transistor Aug 05 '19 at 09:09
