I tried to follow docs, and here is my implementation for triangle pulse:
V1 0 1 PULSE(-0.75 0.75 0m 8.335m 8.335m 0 16.67m 0)
but the result is:
although the Rise time is 8.335m at appears as 0, can someone explain what’s the issue?
but the result is:
Don't ask why, but probably it NGspice fails simulating with a pulse width of 0.
The following will work:
V1 0 1 PULSE(-1V 1V 0 {8.335m-0.5n} {8.335m-0.5n} 1n {16.67m+1n} 0)
EDIT
It seems a known issue: https://sourceforge.net/p/ngspice/bugs/355/
Are you aware of the fact that setting a (pulse) parameter to 0 does not mean that it becomes 0.000000... but that SPICE sees this as a don't care and substitutes it with something (what it thinks is) reasonable? I would expect your actual pulse-width becomes 5 or 10% of the period (I didn't consult the source code for the exact number).
